hey
would an 80L fuel tank out and the FE2 suspension of a VS BT1 fit in a vk sedan easily?
thanks
yep they will fit, only thing I want to check is whether you can use/adapt the VS filler neck or do you need to cut the filler neck off the old tank and use it ?
Should fit fine as long as the vs was live axle otherwise you need to change tank straps and rear suspension. Filler neck goes in but you need to cut down the rubber pipe that joins the filler and the tank. cheers ben
you can use 1 vs stray one needs to be cut and shut with the VK one.
Also you need to make a hose aapter fo the fuel tank vent to step down the venton the filler neck or getone off a VL
scott
ok thanks.. what do yoou mean get one off a vl. then what?
and with the suspension is that just a bolt on thing?
cut the filler neck off a VL tank that way the vent hose will be the correct size., the VN and later filler necks have a larger diameter vent hose
cheers
Scott
ok.. thanks
