Results 1 to 10 of 10
Thread: vk 202 Engine Mods?
    VK Executive 202
    Sep 2009
    Default vk 202 Engine Mods?
    Hey there just wondering if anyone has some idea's of what are some mods that i could do to my vk to give it a bit more power? It's a 202 Carby model Thanks
    Dodge ram 5.9V8, 03 VW Bora, VS 5.0L
    Sep 2009
    Sunshine Coast
    I have a stage 2 cam which will get you a decent bit more. The stage 2 can go into the engine without any modification. If ya do some head work and/or dual carby's or bigger carby you'll get a decent bit more. My 202 was just a little faster then my 253 with the cam and a few other things done to the 202
    VK Executive 202
    Sep 2009
    Cheers, i was thinking of a holley 350 but everyone seems to think their a waste of time?
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by VK 202 View Post
    ive been toying that up, the guy i got my vk off had a 350 and it fangs
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    VH SS
    May 2009
    Toowoomba, Qld
    the factory Varajet will do just fine if it's in good condition & setup correctly. If you really want to ditch the factory carb, go for a Webber like the ones used on XE/XF Falcons.
    VK Executive 202
    Sep 2009
    yeah, atm mines got a blue 202 carby on it and its just about dead, so im open to do anything with the carby really
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    For your biggest gain convert it to EFI
    Else spend your money on making the head work, port the hell out of it, biggest valves you can fit, heavy valve springs and a larger cam something around 480 thou of lift, 112 deg lobe separation 280deg duration valve timing as follows inlet .34/66 exhast .70/30 will give good idle vacume and power around 3200-6500 RPM
    anti pump up lifters
    ACL race series pistons, star fire 4 rods
    knife edge balence the crank, lighted the fly wheel
    you should by then have a weapon of a 202.
    or
    fit a V6 or V8 which will be cheaper and produce more power
    scott
    VK Executive 202
    Sep 2009
    thanks, also by putting on a set of pacemaker extractors would there be much of a gain there? also what would be an ideal exhaust set up? As i want something that is pretty loud with a decent note?
    vr v6
    Aug 2009
    commodore
    Aug 2009
    australia
    everywhere ive read even in dyno tests the factory varajet outperforms the 350 holley on a 6 even street machine magazine tested them and said the varajet was better they all seem to recon the 390 holley 4 barrel is a better choice if going carby route but efi will give a heaps noticable gain i jumped from my stock other than extractors and aircleaner vh into a friends injected 6 cyl vk and the difference was very noticable..
  1. engine mods for a 253?
    By old mate in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-09-2009, 11:53 PM
  2. VU engine mods
    By jakebrake in forum LSx Development and Modification
    Last Post: 09-11-2008, 07:29 PM
  3. engine mods for vx
    By Archers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2008, 10:27 PM
  4. Engine Apart! What Mods Should I Do?
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-02-2008, 06:30 PM
  5. VT V6 Engine Mods
    By 98berlina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-05-2006, 08:25 PM
