Hey guyz. i have just put in a 5speed into my Vk sedan and i'm havn real trouble with the tail shaft atm. i cant seem to find one.. the tail shaft it came with had the wrong end for the diff on it and i tryed modifying it to suit it was to long. the diff i have in it is a Borgy its the U bolts one. so if there is anyone out there with one or knows how to find them that would be great.. i was even thinking about swaping the diff centres ova in it oris that changing the hole differnt diff houseing.?. well cheers for reading if u can be any help to me that would be great thanx..
cheers cam
The borg warner diffs in the Commodores use a flange, the Salisbury's use the u-bolts.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
It wouldbe an M76 5 speed (borgwarner and sailisbury diff) the problem is this combo is rare as, you need to fabricate a tailshaft, cut the end off a borgwarner shaft and then spin down the yoke for the sailisbury on a lathe and then weld it in.
Have info on my site about my tailshaft adventures
cheers
Scott
thanx heeps for your help. All 2day i was on the phone trying to find a shaft but everyone was kept ed telling me i was dreaming.. so i already have a 5speed shaft but its for the wrong diff. Wats so different with the Diff housings..? any chance i could just change the Center and get away with it or do i have to change the housing?
cheers cam
Mate
What you might be able to do is sepearte the 2 sections at the cv joint. Fit your existing rear section that fits your existing diff to the front section that fits the gear box.
If that is no good then you might have to get one fabricated.
I fitted a T5 to my VB with a BW diff and got a VN V8 one rebuilt and cut to suit.
Good Luck
well this is my daily so i'm trying to take it the cheeper way and spend more money on the Play car. If i can swap the diff centers ova that would be great i just dont know if the housings are the same
There was a few VH's fitted with the 5spd and Salisbury diffs....I might even have a tailshaft down the back to fit it (I use to have a VH 5spd with a Salisbury), but I don't know which one is which...these days if we need one we keep trying different ones till we find one that fits lol.
Ya might get away with using the M76 yoke on the front of ur current tailshaft.
$450 brand new from hardy and spicer or something like that
