Results 1 to 5 of 5
Thread: vh 308 trimatic to t5 v6 conversion questions
    Vh sle 5ltr 83
    Mar 2008
    Default vh 308 trimatic to t5 v6 conversion questions
    ok first question any change to the tail shaft is it an easy fit do i need to change the exhaust at all, can i just use my standard pedal box, is there anyone around that would do it for me ?
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    You will need a T5 yoke fitted to your tailshaft. You would need a y pipe and cat. If your system is a 2.5" you might be able to use the rear section. You will need a clutch pedal fitted and change you auto brake pedal to a manual so probably easier to change it.
    The electrics need to be considered as well. You will need fabricate a gearbox crossmember.
    Your suspension for a V8 would be better changed to a 6 cylinder springs otherwise could be too rough.
    There is a thread about it on this site. Read it. It is most helpful.
    I have just almost completed mine. If you were to pay someone to do it it would cost a fortune. Their is plenty of info on this site.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    Vh sle 5ltr 83
    Mar 2008
    Jul 2009
    Melbourne - SE
    All of the above plus steering rack and the lower part of the steering column.
  1. v8 trimatic few questions
    By 50 stevo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-02-2006, 03:35 AM
  2. FS CRS trimatic to turbo trans conversion kit
    By Cane_It in forum Parts And Other Items For Sale
    Last Post: 19-11-2005, 06:07 PM
  3. VK trimatic to manual conversion
    By VKMaverick in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-11-2005, 01:20 PM
  4. VH 6 CYL Commodore Trimatic To T700 Conversion
    By malemailmaleman in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-10-2004, 02:10 AM
  5. Vh Sle Trimatic Conversion
    Last Post: 02-04-2004, 07:40 PM
