Results 1 to 20 of 20
Thread: where to mount immobilizer on vh?
    budgieVH's Avatar
    budgieVH is offline get in shut up nd hang on
    Injected 5ltr VH SL/E-VH Blue 202-GQ Nissan Patrol
    May 2009
    Australia
    Default where to mount immobilizer on vh?
    hey guys i got my alarm system.. i just dont know where a good spot is to mount my immobilizer in my vh commodore..
    if you guys have after market alarm systems where did you mount it?
    thanks and have a good week end
    Budgies Car Sound
    Facebook www.facebook.com/budgiescarsound
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    don't make it to easy to get too , but remember its only going to slow them down and alarms can be easily bypassed , mine was mounted behind the instrument cluster and not visible from the foot well .
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    i wouldnt even bother going to much effort to hide it they are so easy to start anyway it will make it slightly harder to stop it making a racket but meh
    strgas's Avatar
    Oct 2009
    air fuel or spark remove one of the three and the car wont go to far ????
    budgieVH's Avatar
    May 2009
    Australia
    i was just thinking in between the front right panel and the plastic interior next to the accelerator pedal. it isn't visible unless you took that plastic bit off but it will be well hiden. the by pass switch i was just going to tuck away in my fuse box..
    i was thinking about putting it behind the cluster but to much messing around..
    i looked under that plastic bit pf interior above the pedals but not much room or a good spot to mount it.
    Budgies Car Sound
    budgieVH's Avatar
    May 2009
    Australia
    Quote Originally Posted by strgas View Post
    i have a fuel line solinoide rite infront of carbie.. but i have expansive stereo and alot of work done to interior ect lol
    Budgies Car Sound
    strgas's Avatar
    Oct 2009
    mount it under the rear seat . the module isnt the problem its the wiring to and from and as most good car theives no the wiring back to front it wont take long to get around what ever you do . then there is always a tilt tray to worry about ????
    budgieVH's Avatar
    May 2009
    Australia
    wiring and thieves isn't my problem just yet.. the system has black wiring. all i asked is for mounting options and opinions lol
    Budgies Car Sound
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by budgieVH View Post
    it wont matter even if its pink wiring its easy to get around.
    It will cut the ignition wire, damn thats hard... alligator clip a wire from the battery to the coil.
    Starter motor wire disabled, simple short the starter motor out. easy esp on a holden 6.
    So go get yourself a fuel cut off solenoid from a gas conversion place find a real prick of a spot to mount it and wire that up so if they cant get fuel and they can access the solenoid to open the fuel line they had better to geta tow truck or car trailer
    Scott
    budgieVH's Avatar
    May 2009
    Australia
    i have a fuel cut off line already! question is where to mount alarm...
    dont worry about it ill post some where else
    Budgies Car Sound
    strgas's Avatar
    Oct 2009
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    mount it under the cash crash pad where the VH/SLE or VK/VL calais hae dash speakers on the RH side of the car, prick of a spot to access unless you remove your crash pad
    Used to be a good spot to fit radar detectors
    cheers
    Scott
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    Quote Originally Posted by ari666 View Post
    id say mount it behind your radio.
    if you could fit it ive got no room behind mine my deck dosent even go all the way in
  15. #15
    budgieVH's Avatar
    May 2009
    Australia
    okay...
    what i have done.. in the vh commo where the fuse and relay area is i un screwed that part of interior and there was stacks of room behind there... i mounted it rite at the back of the fire wall behind the cluster. bit of a pain but oh well. next week i will have to take it out again to wire up the central locking kit kill start!
    Budgies Car Sound
  16. #16
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by v8commy View Post
    sounds like someone needs a lesson in cable ties and cutting wires to length
  17. #17
    strgas's Avatar
    Oct 2009
    sounds like another quality strathfeild install ... just jam it in and roll up the extra wires and stuff-em up under the dash
  18. #18
    budgieVH's Avatar
    May 2009
    Australia
    haha no good... least they dont tape wires together! i have seen that done by auto barn once
    Budgies Car Sound
  19. #19
    strgas's Avatar
    Oct 2009
    hmmmmm taped together one step away from a scotch lock ??? always solder and never have a problem again . Seen a install from there sth melb branch some years ago and they just stripped the wire and pushed it into the back of the ignition switch connector block not even on the acc side ... top marks for that one guys ......
  20. #20
    budgieVH's Avatar
    May 2009
    Australia
    ohh ouch!
    i either solder or crimp.. i build laser machines dooing all the electrical stuff and if we did that at work id get in shit and it would endanger other peoples safety haha blew up a 600volt power supply once!
    Budgies Car Sound
  1. is it posible to add on to the immobilizer
    By rob drag racer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-05-2009, 04:04 PM
  2. high mount and low mount turbo???
    By treezey in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-02-2009, 07:12 PM
  3. High mount log manifolds VS front mount extractors
    By PaRaDoX in forum V6 Development And Modification
    Last Post: 04-04-2007, 06:15 PM
  4. VP Immobilizer swap over from another VP
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-11-2006, 06:55 PM
  5. Vp Immobilizer
    By Mad Dog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-03-2004, 07:36 AM
