Results 1 to 5 of 5
Thread: vh sle lights
    Vr BT1 5lt
    Jul 2009
    Frankston
    Default vh sle lights
    hey my brother has a vh sle ser 1 253 and when he is driving along at night with the lights on they are bright. but now and again they will go dull and then go back to being bright. Now while driving it i have noticed when the lights go dull the volt meter is droping power but when they are bright the volt meter seems to sit way to far to the right off the meter???
    also he just had an immobiliser fitted and when the car seems to heat up hot and then you stop and then try to start the car again it tends not to want to kick over???
    Any help would be appretiated.
    Cheers Mick
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    souds like a bad earth, check, renew earths
    earthing circuits are on my site
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    it should be running at 14.5 volts. which is way over to the right. it shouldnt drop below 8 volts. try vkbelinas suggestion then check your alternator belt tension.
    having your idle speed too low will mean your alt will not charge. so when you are stopped at a red light your head lights/taillights/radio/heater fan etc etc etc are all running off battery voltage. so maybe tune it up a bit.
    Vr BT1 5lt
    Jul 2009
    Frankston
    Quote Originally Posted by ari666 View Post
    ill give it a go and get back to you Cheers Mick
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Also something else to add when i had a charging prob on my VK I was running the correct belt however the belt sat too low on the pully and bottomed out, I ended up having to get a wider belt to fix the problem
    cheers
    Scott
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. VR Commodore garnish lights and number plate lights not working...
    By cody84 in forum Electrical Wiring / Questions
    Last Post: 23-09-2009, 07:41 PM
  3. [SA] vt/vx centre lights with map light and.... calais courtesy lights wiring/set up
    By callum_88 in forum Parts And Other Items For Sale
    Last Post: 11-05-2009, 07:58 PM
  4. Replies: 3
    Last Post: 26-10-2006, 05:43 PM
  5. No Parkers, Speed Alert, dash lights or shifter lights.. Help..??
    By Grommitt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2006, 10:36 AM
