Got a small problem which we need to fix b4 2morrow lunchtime (well 2day now)....we chucked a 308 in my VK wagz which was a 202....but the accelerator feels weird, like it doesn't have much movement, and the carby isn't opening fully.
We're using a v8 throttle cable, which is fully adjusted.
Is there anything different from the v8 and 6 cyl accelerator pedals?
Wat's the easiest way to get more movement out of it?
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
get a pedal box from a v8
Nope no diff between pedals at all. The cable could be stretched.
if you have a spare hole on the throttle linkage that is closer to the centre shaft it will pull further for less pedal movement
there is also a screw on the pedal which adjusts you bumps. that messes with your little "slidey thingie". just make sure you have full play with that cos the little slidey switch will stop some of the acc pedal travel.
Turns out the pedals are different. So changed them over and it fixed the problem.
