Results 1 to 15 of 15
Thread: Brakes bind up after a while
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Default Brakes bind up after a while
    Just sorting out a few issues.
    My main issue is that after 10 minutes or so the brakes gradually come on and the pedal becomes harder and harder. You can feel that the car does not want to roll freely. All 4 wheels are hot.
    If I leave it for 10 minutes or so the problem fixes itself. My vb is running VN V8 disc brake set up with a 1" master and V8 booster.
    Is this a stuffed booster?
    Pete
    Sabbath''s Avatar
    Sabbath' is offline Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    How long ago did you last change the brakefluid?
    If there is high water content, it lowers the boiling point of the fluid,causing decreased pedal performance.
    Also moisture could be causing premature rusting of some components.
    Jul 2009
    Melbourne - SE
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    my booster did the opposite when it died. started leaking vac on braking and had no suck, so you had to use both feet to get her to stop suddenley. i cant imagine why they would 'pull' on your brakes.
    so all 4 wheels do it? it wouldnt be one wheel with a stuffed piston? creating too much pressure on the other 3?
    Jul 2009
    Melbourne - SE
    Could be I will check the rear calipers for a start. The rear diff sat around for a while before I installed it. Was not too sure where to start.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    Check the brake pedal pushrod for free play , and the booster rod for free play ???
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    I would say it doesn't have enough pedal freeplay so the brakes aren't releasing fully.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Check those rear calipers, they have a tendency to seize.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by ScoHar View Post
    i 2nd that. thus putting too much pressure onto the fronts and causing them to engage.
    ScoHar's Avatar
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Quote Originally Posted by ari666 View Post
    especially if you've just fitted new pads also
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Wink hmmmmmm sounds like something ive seen
    Ive seen this on a VT R8 clubby, friend of mine had her brakes done and fluid changed, then a few days later she rang and said her car had lost power (supercharged LS1) and had a hard peddle after driving for 10 mins, it ended up being the brand new fluid was contaminated and caused all the rubbers to swell once warm??? weird.... but it killed every rubber in the braking system cost her $$$, The brake place didnt help her one little bit the bastards!!! once all rubbers changed and new fluid was good as new... might be something to look at, maybe just pull one caliper off or look at master cylinder piston rubbers see what it looks like???
    Mike
    YT
    Jul 2009
    Melbourne - SE
    I am rebleeding the brakes with a different fluid to start with in case it has water or air in the system. I will check all the calipers to ensure that they are not binding.
    I suspect that it is not a simple answer like that.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'd be checking the valve that the hose connects to on the booster. If it is stuck open, it will have constant vacuum pulling on the booster, engaging the brakes.
    Visit my Facebook page
    Jul 2009
    Melbourne - SE
    I think it must be booster or master cylinder related.
    After I bled the brakes again and check the operation of the calipers I was going to disconnect the booster vacuum line and see if the problem continues to happen. If it continues to happen i think it would have to be an issue with the master cylinder.
  15. #15
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    Quote Originally Posted by Not_An_Abba_Fan View Post
    thats only a one way valve, that way the booster maintians vacuum when you have no vacuum in the intake manifold. hence the reason the vac assist (for 1 or 2 pumps of the brake pedal) still works with the engine off.
    MICKY.D's answer sound logical but the most expensive.
    i'd strip one rear caliper and check the condition of the rubber seals.
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Bind Cricket
    By INNAWE in forum Jokes/Humour
    Last Post: 23-09-2009, 12:04 PM
  2. Brakes
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-12-2008, 09:53 PM
  3. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  4. Better brakes
    By 97 SEN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2006, 12:48 PM
  5. Brakes
    By mitch01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2005, 03:45 PM
