Results 1 to 5 of 5
Thread: carbie black 202 no spark
    86vk commodore
    Nov 2009
    Default carbie black 202 no spark
    i have scored a vk commodore on gas with a 2 year old paint job and a set of 17s for 400 bucks problem is no spark i have replaced the coil dizzy cap rotor button leads and plugs and my cut of switches its got power at the coil but no spark at the plugs
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    ok so check the two wires from the dizzy to coil are both connected and on the crrect terminals
    whats a cut out switch? you mean points?
    bpefi is offline Tech
    Hilux Ute - Vs Ecotech Engine
    Nov 2009
    Bundaberg
    For spark problems lift the cover off the side of the distributer & check out module - make sure its dry & connections good - you will want to put screws back in if you want to check for spark with the cover off as it earths the module through the screws. Without the approriate testing equipment you will have to check that you are getting power to the coil & module - that the distributer is turning - plastic gear strips as does the camshaft driven gears - if it has power & connections good replace module - should be around $60 or take coil & module to a mechanic for testing. Good luck
    85 VK SL - 79 VB 253
    Jun 2009
    NSW
    Quote Originally Posted by bpefi View Post
    Great advice, but....
    If it is a VK carbed and stock, it will have EST (Electronic Spark Timing) and therefore no module.
    My advice is to check your dash lights for the EST lamp and if it is lit, search this site (and others) for some potential solutions.
    BTW welcome aboard bpefi, buckle up, hang on & enjoy the ride!
    86vk commodore
    Nov 2009
    est light is lit so does that mean its cactus
  1. spark plugs for black 202
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-08-2009, 09:30 PM
  2. only one black spark plug
    By HSV472 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2008, 09:24 PM
  3. 202 black carbie
    By oxmate in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-10-2008, 06:41 PM
  4. 202 black motor carbie and auto gearbox
    By sexypete in forum Parts And Other Items For Sale
    Last Post: 07-04-2006, 11:59 AM
  5. Fs: Vk Black 202 Carbie, Manual 5 Speed - 900ono
    By mplac in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-10-2005, 01:04 AM
