Results 1 to 25 of 25
Thread: will it cool
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    Default will it cool
    can someone tell me if this ill cool my vk 308 cammed,head work, full exhuast stage 2 shift kit vlt diff 345 ratio 16 INCH LOW PROFILE HIGH PERFORMANCE THERMO FAN - eBay, Other Car Parts, Accessories, Car Parts, Accessories, Cars, Bikes, Boats. (end time 09-Dec-09 11:37:54 AEDST)
    VS Calais & vh sl
    Dec 2006
    deception bay
    I have one in my vb trying to keep the 350 cool, it works ok but sitting in traffic for a while (20mins or more) it does/will overheat.
    vk calais 5.0
    Mar 2009
    reynella sa
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    you will need much more coverage than that one fan. either two fans offset or a shroud that covers everything.
    search around on here for the VT upgrade. my mate did it to his ute and he is happy with it, but it des drag a lot of amp's so you will need to upgrade your alternator regulator and pulley.
    vk calais 5.0
    Mar 2009
    reynella sa
    vk calais 5.0
    Mar 2009
    reynella sa
    VS Calais & vh sl
    Dec 2006
    deception bay
    its 30mm wider but you could get it to fit if your creative. at 21.5" ( 546mm) wide x 17.5 (444.5mm) high the thing to watch out for is the position of the fans if its bigger than the core you need to have enough room on the cowl to cut clearance for the inlet/outlets.
    But twins will be more efficient than a single.
    ari666's Avatar
    1966 impala
    Mar 2009
    personally i would get two 16's and offset them... but thats just me. if your fan shroud overhangs the radiator itll suck air from the direction of least resistance i.e. the gap, not the rad. so a bit of stickytape and some cardboard maybe
    vk calais 5.0
    Mar 2009
    reynella sa
    Quote Originally Posted by ari666 View Post
    but there is no way near enough room to put two 16" fans that would require 32"s that i dont have but thanks for your oppinion bud
    vt ss & lc gtr
    Jan 2006
    Use the ford el fans or mondeo fans.
    Also fit up a vn-vs v8 alternator.
    A single 16 inch just wont work good enough when you're stuck in traffic.
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by v8commy View Post
    thats strange, i have two on mine... guess you got a different radiator huh?
    lol.
    VS Calais & vh sl
    Dec 2006
    deception bay
    lol.
    id like to see that i have a single on mine and theres now way (no matter what you do) another will fit.
    El falcon are to wide but the mondeo are a good fit apparently
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    What about one on the front, and one on the back on the opposite side to the one on the front.....that'll work. Obviously one will be pulling, and one will be pushing.
    ari666's Avatar
    1966 impala
    Mar 2009
    lol.
    ok, so i was being a twat, measured it last night they are 12 inches.
    soz everyone. my bad (stupid imperial measurements)
  15. #15
    vk calais 5.0
    Mar 2009
    reynella sa
  16. #16
    VS Calais & vh sl
    Dec 2006
    deception bay
    Quote Originally Posted by DANNY8 View Post
    id like to know if that would actually do any better than a single cause as far as i can see it would still flow the same amount of air.
  17. #17
    vk calais 5.0
    Mar 2009
    reynella sa
    i got the fans really good quality and am thinking of getting a pwr trans cooler and just doing it all at once what your oppinion aww and getting my radiator overhauled is guage ment to be sitting at half way?
  18. #18
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by 180sc View Post
    Yeah but the coverage on the radiator is better.....which is wat ya need. If ya have one fan in the middle with no shroud, it's only gonna pull air through that circle, so if idling, only cools a small amount of coolant in the radiator. More fan coverage on the radiator is the way to go....which is why a proper shroud makes a huge difference.
  19. #19
    vk calais 5.0
    Mar 2009
    reynella sa
    yeh i have to mount it in front of the radiator i mounted it behind to realise that its a blower not a sucker
  20. #20
    DANNY8's Avatar
    Apr 2004
    Ya reverse the polarity to change the direction it spins.
  21. #21
    VS Calais & vh sl
    Dec 2006
    deception bay
    mine sits halfway between the blue bit and half on the gauge but thats not much help cause your gauge is different, i would get it overhauled if its getting on in age.
  22. #22
    vk calais 5.0
    Mar 2009
    reynella sa
    there in with head **** they do a good job of cooling providing you have them on otherwise it overheats but then the trans coller in my rad went and i now have trans oil in my coolant and coolant in my trans so mid next week trans is getting pulled out cleaned getting the converter stalled up and new clutches all for $600 not a bad price i thought but from putting thermos to this **** im pissed off but i had to be done soon anyway the clutches are pretty ****ed in it but owell what to do
  23. #23
    VK sold.. VN3.8 and VX aclaim
    Aug 2009
    south auckland
    2 smaller fans should provide more coverage than a large single...natuarly all is dependant on cooling system condition etc... EngineTiming can have alot to do with operating temp.....(found out the hard way lol )
    Floor it and swerve driving skool
  24. #24
    vk calais 5.0
    Mar 2009
    reynella sa
    yeh went and got some hd cooling sytem flush ,coolant,new thermostat cant wait to get the tranny done gonna goe so much harder
  25. #25
    vk calais 5.0
    Mar 2009
    reynella sa
    yeh trans is out its now got a stalled converter to go back in, getting new clutches, a new band ,a softer spring of some sort will make it switch alot quicker , and a new ring its for the reverse gear the band runs on it and over the years its had some damage put on it so now all up $800 be done on tuesday then i will flush the cooling system and she'll pirr again now as for the fans i left the car running with the fans on for 5 mins and the guage didnt move so im guessing that there gonna cool it alright but im getting a thermo switch soon enough cant be ****ed remembering to turn them on
  1. Do you consider this cool!
    By calais_304 in forum The Pub
    Last Post: 03-12-2009, 11:44 PM
  2. This is cool!!
    By Hunter SS in forum The Pub
    Last Post: 06-06-2009, 12:39 PM
  3. To keep my cool..
    By vsdeath in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-04-2009, 04:38 PM
  4. A cool kit for your car
    By craigvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-11-2005, 03:01 AM
  5. This Would B Cool
    By spice_man2069 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-10-2004, 09:37 PM
