i was looking to put a rb30 into my vk commy and was after help on the driveline, if you have to change cross members ect. thanks
You need to change the k frame, rack lower section of steering shaft. I think in the vk the gearbox xmember is ok. Fuel tank and fuel return line if not fuel injected. Wiring loom + ECU. Get a donor car is easiest.
why do you need to change the k-frame? surely just changing engine mounts would be ok...
i was going to get a vl donor anyways, cheaper to do that than just get a motor, well here in rocky any way. so i wont need to change the diff, brakes F & R??? thanks for the help. ill keep you posted
It may be best to change the diff even it it is BW. THe diff ratio in the VL is a 3.45 the vk is most likely a lower number. Need a cat to to be legal.
so just a vl k-frame would be ok??? that was another question, would it be legal???? as of the monster T3/4 turbo and intercooler.
You will need to upgrade the brakes to vl turbo or better. Check with your road authority. Most likley need an egineers. My son and I converted his VH to a rb30 turbo.
scrap the single turbo.... i priced 2 brand new turbo's and its cheaper buying 2. is it possible to push 9sec's out of a rb30twin turbo and still have it legal to drive??????
twin turbos are a waste of effort
twice the cost and you only gain the wank factor
you will need much more
custom exhaust manifold to suit the two turbos, plumbing for the intake or cooler, 2x oil feeds, 2x oil drains, 2x water feed, 2 x water drain, 2x custom dump pipes, custom front pipe etc
twin turbo is good for response
single is good for power
going from a 202 to a rb30et you will be making a massive jump in performance let alone thinking of a rb30ett set up
start with the rb30et first before you think too far
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Mate You will need to discuss with the RTA or an engineer.
Single turbo to manufacturer's specs ok in vic with engineers.
yerrrrrrr to much f#*King around.... single will be fine. thanks for the help ppl
Mate
We used the VL loom. Cut of all the connectors to the lights etc off the vh loom and soldered to the vl loom. We replaced the vh dash with a vl dash.
A lot of f**king around.
Pete
From memory the windscreen rubber had to be trimmed back, had to use the vh heater and fan controls. Some of the ducting need to be modified a bit to fit.
The cluster fits differently so best to get the supporting section from the VL donor and fit.
It could have been made a lot easier if the VL cluster was fitted to the vh dash and rewired the light wipers and heater fan controls.
At the end of the day this is a great car. Not many RB30turbo VHs getting around.
It was oriiginally fitted with a standard RB30 and latter upgraded. Photos are taken during engine transplant, car ready for rego and as bought. It was a two year project. You can see my red VB in background of the first photo.
