Results 1 to 11 of 11
Thread: interchangeable parts help
    VB SL commodore and VN s1 v6 5speed exec
    Apr 2009
    Airport west
    Default interchangeable parts help
    hi guys just wondering if anyone could tell me what parts are interchangeable between the vb to vk commodores
    cheers
    OzzRocker
    sycvs is offline commo for life
    vs executive
    Jul 2009
    phillip island
    head lights taillights lots more think some panels and body parts think most of interior and engine thay are bassicly the same car just vk plastic bumpers
    what parts you looking to swap over
    Apr 2009
    Airport west
    i was thinking of putting a vh hood on my vb coz it has a hornet scoop on it
    Apr 2009
    Airport west
    also what diffs will fit a vb? i want to put in an lsd but dont have too much knowledge when it comes to diffs
    vs executive
    Jul 2009
    phillip island
    carn't see why not im 99% sure they are a clean fit vk is different i think (bit to sharp in the center ) please quote if im wrong
    vs executive
    Jul 2009
    phillip island
    Quote Originally Posted by OzzRocker1 View Post
    im the same with diffs although when i took 1 out of my old vk (lsd ) it fitted my vs wagon and they are ment to be different but its the same with uni joints and tail shafts i learnt that due to needing parts and took them off my old vk to fit my vs
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    OK. To fit the VH bonnet onto the VB, you need to swap the guards too. The bonnets are the same.
    Diffs, VB-VL sedan diffs fit sedans, wagons fit wagons.
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    to fit a late VK diff (BW) into a VB (and upto the early VK's which had the salisburydiff) you will also need to change the rear half of the driveshaft.
    the VL diff is also 12mm wider then the VB-VK diffs (and from VN onwards it is 40mm wider again)
    Body by Holden, Soul by Brock
    the Legend will live forever
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by SL/ENUT View Post
    Just incase you got confused, that was a typo, bonnets are not the same hence the need to swap gaurds
    Apr 2006
    Auckland NZ
    Quote Originally Posted by greenfoam View Post
    and then you would also need to swap the headlights and the grill as they are also different
    SL/ENUT's Avatar
    May 2004
    Burnie, Tasmania
    Ahhh so it is, whoops. I meant to aren't the same.
  1. Are the VT & VX SS LSD interchangeable
    By ozengines in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2008, 07:34 AM
  2. VZ-VT headunit interchangeable?
    By ascension24 in forum Car Audio
    Last Post: 04-08-2008, 11:08 PM
  3. Are Vn And Vp Struts/suspension Parts Interchangeable???
    By NOGEN 3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2008, 02:01 PM
  4. VT and VX panels interchangeable?
    By TGibson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-09-2007, 10:24 AM
  5. interchangeable parts
    By mrbeef in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2007, 10:19 PM
