Well, I'm looking at building up a VK wagon project, Just buying a rolling shell and buying the motor and box, But have a few questions.
1. Would an EFi 304 bolt straight in to the wagon or would I need to get new K frame and engine mounts etc. ?
2. Could I bolt a T5 box straight in?
3. What would I need to do for wiring?
And does anyone have any guides/manuals/information on the conversion? Would be much appreciated. Cheers
fyi, if you search in the VK section you wont get as many results.
If the car you buy was originally a V8, the k frame will be fine.
The T5 wont be a straight bolt in, you will need a custom cross member (theres a place that sells them)
Originally Posted by davway
I think it was about the $200 mark for one.
I had a mate make one up for me (was using a V6 and T5)
Don't understand what your saying about the V6 thing, if your meaning you want to use a V6 k frame with the V8, that wont happen, they are different (my VK was originally a V8, and the frame needed to be changed to a V6, if i pout another V8 in, it could have stayed)
Oldest car i've owned is VK, so someone else will have to answer for sure.
All the Commodore's from VB to VK run only one K frame, the Aussie 6 and V8 both use the same K frame, so you wont need one. I posted a file somewhere on here last time someone asked this that detailed the complete conversion
Yeah I used my 6cyl crossmember for my 5.0L.....bolted straight up. Not sure bout the t5, but if ya use the t700 ya need to use power steering (unless ya start grinding away at the tranny case) and pacemaker have a set of extractors to suit vn style heads in vb-vk commodores. I was gonna use a t350 box so I could keep the manual steering, and the trimatic tailshaft and crossmember SHOULD fit with no drama's. I ended up going back to carby b4 I even finished the efi conversion tho....I'm glad I did!![]()
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
