Results 1 to 4 of 4
Thread: Vb sle
    VZ SVZ Wagon
    Nov 2009
    Default Vb sle
    Hey Guys
    I have a VB SLE A fairly basic car with 253 and traumatic but I retrofitted a VK 308 and T350 Pretty easy fit except I cant get a damn speedo cable for it. I go to cov's/repco and they cant identify it from the numbers of course because I changed it. So where do I get a speedo cable for it. also I need to adjust the speedo to suit the change from 2.78 ratio diff to 3.08 but soon to be something else because I can do 150 in first with the 3.08 so I am guessing a 3.55 will be better but I would love the speedo to be reasonable accurate.
    Has anyone else had to beef up a chassis on one for big horsepower?? I have nearly 500 but it twists like nothing else and snaps engine/gearbox mounts regulary. I was going to stiffen the chassis but I cant be the first person to pump 500 into one so what has everone else done??
    Cheers Bevo
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Any reasonable instrument repair guy can make you up a speedo cable, ring around. you may need to supply the ends for the gear box etc.
    check my site for speedo gear charts, i also have a pretty good range of old speedo gears work out what you need and i will probably have one.
    500hp pretty impressive, seam weld the body, plate suspesion arms, install a propper roll age, convert to a link rear end.
    scott
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Mate
    Try castlemaine rod shop.
    The organised me a T5 to VB dash. $88+post.
    You just need different gears at the gearbox connection.
    VS Calais & vh sl
    Dec 2006
    deception bay
    Ebay is where i got mine $60 from memory same cable for t400 and t700 aswell.
