Results 1 to 20 of 20
Thread: 308 into 202 vh
    VL EXEC
    Aug 2008
    perth wa
    Default 308 into 202 vh
    may be purchasing a good condition running registered vh for 1500 and just wanted to know whats needed to put a 308 into it if there is a thread already describing this feel free to direct me
    I've driven fast cars I've done stupid shit in them each time i seem to come out on top i love you guardian angel
    vp ss 3 months to go
    VH SS
    May 2009
    Toowoomba, Qld
    it's relatively easy - I did it with my last VH.
    Wiring is easy, simply unplug the 6 cylinder harness from the firewall plugs on the drivers side, and plug the V8 harness in.
    308 literally drops straight in, just need to use V8 engine mounts.
    fit a V8 radiator
    gearbox mount/cross member, depending on what transmission you are going to use
    If you haven't already got rear disc brakes, then you need to upgrade. Also need to use a brake master cylinder to suit disc rear or you risk dragging the rear brakes.
    that fairly much covers it.
    custom vk Calais
    Jan 2009
    you will need :
    motor
    box
    starter/m
    alternator
    fuel pulp
    carby
    tail shaft
    lsd diff (if you don't have one)
    complete exhaust
    v8 brakes
    v8 springs
    wiring
    radiator
    box cross member
    engine mounts
    just all that type of stuff but you have to factor in things like are going to put a kit through the carby ? $60 -100
    air filter ? $80-$250
    fuel fittings ? as much as you like if you want but not that much for basic stuff
    gaskets for engine and exhaust ? $5-$150
    leads? $80 -$150
    plugs ?$30-$120
    tuning ?$200-$400 if you cant tune it
    power steering lines ? shouldn't cost much
    are you going to run air con ? lots and lots lol
    you rpm will be out ? auto metre tacho $600 but you can get one allot cheaper lol
    i prob forgot things but you get the picture
    there are heaps of little things but its not that hard if you know what you are doing or have some mates that's can help you out.
    i will add that you can do it the quick way or the right way once lol its up to you what you do at the time
    you can do this a hell of allot cheaper than what i have said above but if you don't have contacts and don't know the right places to go the prices above are what you COULD pay.
    hope that helps you out mate
    VH SS
    May 2009
    Toowoomba, Qld
    LSD isn't necessary, was only ever standard on select models like the SS. If you already have a disc brake rear, then no need to change it over. The 4.2L used the same diff as the 6cyl disc brake models. However the smaller diff won't take much punishment from a 5L so a 10 bolt diff is a worthwhile consideration.
    As for tailshaft, it just depends what transmission you are using. From memory the trimatic sits in the same position in which case you can use the same shaft. If upgrading to a 10 bolt diff, you will need the larger yoke tailshaft.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by ari666 View Post
    try doing this:
    he may not know how
    Please click here
    oh also, that says 308 in vk ari666.. lol
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    VL EXEC
    Aug 2008
    perth wa
    --deleted--
    VL EXEC
    Aug 2008
    perth wa
    try doing this:
    u try making the search smart ass
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by VryNeat View Post
    settle down, this has been answered before, just don't just try searching one thing, search for v8 vh, there is someone on this forum that has all you need to know about EFI 5L in vk's in their sig, ask him, thats close enough to it.
    just keep searching around and you'll find it..
    vkcommo
    VL EXEC
    Aug 2008
    perth wa
    Quote Originally Posted by vkcommo View Post
    vkcommo
    i searched all the key words possible on these forums and in google i couldnt find anything hence saying if someone has a link feel free to send it to me otherwise i was in need of the information
    ari666's Avatar
    1966 impala
    Mar 2009
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Default This Is A Heading
    PM vkberlina, scott is his name, he knows all there is to know.
    otherwise, if you scroll down the page a little:
    What motor will fit in my 1982 vh commodore wagon sl vacationer
    VK Berlina Project
    bingo.....
    VR Calais
    Apr 2005
    If you were dropping in a 308 in place of a 202, what could you do to keep the power steering from the 202? Is it at all possible or completely different pieces of kit?
    thanks
    ari666's Avatar
    1966 impala
    Mar 2009
    i had the mammoth task of finding a high pressure hose for a V8 pwr steer. i could find 6's no probs at all. dime a dozen. every stinkin' hose on V8's at the wreckers were either perished or stolen ended up paying 60 bucks for a meh hose from a crappy wrecker. so if thats any guide, i would say 6's are different, but cant say for sure.
  15. #15
    VH SS
    May 2009
    Toowoomba, Qld
    just get someone like Enzed to make up the hose - probably could get a brand new hose for that sort of money
  16. #16
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    just go to pirtek and buy fittings and hose to suit they do most things like that
  17. #17
    ari666's Avatar
    1966 impala
    Mar 2009
    enzed wanted 150 to come out and do it. anyways this os OT the guy asked if 6 PS was the same as 8
  18. #18
    VR Calais
    Apr 2005
    Can the actual pump unit just be swapped over though? Is the hose the only difference?
  19. #19
    ari666's Avatar
    1966 impala
    Mar 2009
    i checked with burson and they only have the one pump part number for VK, so i would guess 6 and 8 is the same.
  20. #20
    VR Calais
    Apr 2005
    Ok, cheers for the help
