Results 1 to 3 of 3
Thread: oil press reading on 202 VH
    budgieVH's Avatar
    budgieVH is offline get in shut up nd hang on
    Injected 5ltr VH SL/E-VH Blue 202-GQ Nissan Patrol
    May 2009
    Australia
    Default oil press reading on 202 VH
    can you get an oil press reading from the stock oil press sender thats in the engine or do i have to use the one that comes with the gauge? (its electronic)
    i did put the brand new one in that came with the gauge but snapped the bigger
    inseart in side the engine.. i got it out though and just put original one back in for now and
    wired it up but soon as i start the car the gauge goes to the big fat 0 mark..
    engine is strait 6 blue 202 3.3ltr
    Budgies Car Sound
    Facebook www.facebook.com/budgiescarsound
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    um, there is only one sender which is on the pump (bear with me cos' 6's are not my specialty) i dont know what second one you are talking about, you sure its not just a temp sensor? you can get a reading from the sender without you oil pressure guage with a multimeter. basically with the car running you hold neg term of multimeter to the body of the sender and pos term to the little clip bit and the resistance is your pressure reading. i think the resistance readings are on this forum somewhere.
    edit* ah i get it, you got a sender with your gauge and you broke the sender? if thats the case it sounds like the sender might be specific to the gauge. if the resistance readings are higher or lower, or if they use 0-12V for a reading then ou will need to get a new sender to suit the gauge.
    budgieVH's Avatar
    May 2009
    Australia
    cheers for the help. i got the sender fixed.. it was the brass insert witch makes the thread bigger.. got the specialized one in the engine now with the press gauge. it reads around 20 on idle and around 40 when flat out.
    yeah oil sender is near the oil pump and filter on my car.
    Budgies Car Sound
  1. Where to buy V6 Oil Press sensor
    By VZnut in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-08-2009, 06:02 PM
  2. SA - Bench press plus weight set
    By Caprice5L in forum Parts And Other Items For Sale
    Last Post: 13-09-2008, 12:20 PM
  3. wtb. electric oil press gauge S.A
    By GTP 85 in forum Swap / Wanted to Buy / Trade
    Last Post: 19-08-2008, 01:59 PM
  4. press remote once driver door up press again back down wtf
    By jarred193 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2007, 10:35 AM
  5. 'Press Remote' ?
    By Swift in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-07-2006, 11:01 PM
