Results 1 to 5 of 5
Thread: Sports cam for my VC
    morsario Guest
    Default Sports cam for my VC
    Hey,
    I just installed a 2 1/2 inch Lukey Exhaust and Lukey Extractors to my 202 blue motor. I think i may have a problem with lack of back pressure because, when the engine is cold it has very little power in low rpm, and even when it is warm, i dont think it has the power it should have in the low rpm range. Although it is fine at high rpm.
    I was wondering if a sports cam might fix my problem? If it would help, how much do you think it would set me back $$, and would it be worth the money.
    Thanks
    Aaron
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    It sounds about normal, the idea for extractors is to produce power at a higher RPM range, the size of the exhaust you have put on the car is too big for a stock engine anyway, really you would deen a pretty wild 202 for an exhaust like that.
    Im talking engine with, wild cam, big valves etc
    Before you go making the car worse, what do you want the car for, daily driver, hoon car or weekend warrior type of thing?
    If you go and put in an agressive cam, do the head work it will be a pig to drive in traffic, i have been there done that. It would go pretty well at WOT flat out through
    Also is fuel economy or lack of a concern for you?
    cheers
    Scott
    morsario Guest
    Well, its a weekend warrior, but i use it to drive to work through the week. Fuel economy isnt to much of a concern but i dont want to be going through **** loads of fuel just to get to work.
    Thanks
    Aaron
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    ok,
    If you want it to go I would suggest something like the following cam
    IN.40/74
    EX.78/36
    inlet dur 294
    exh dur 294
    inlet .050" Dur 246
    exh .050" dur 246
    Inlet lift .507"
    exh list .507"
    112 lobe separation
    It will require roller rockers and a serious head job with big valves and either a bigger carb or EFI with high flow injectors, at least you will make use of the exhaust
    Flat out would give you around 350-400 out of 83l combo of around town & highway around 400-450/83l
    really if your looking at all performance out of a 202 you really need to consider rebuilding a 202 to suit the application, balenced bottom end, good rings & bearings, light weight pistons, good rods.
    cheers
    Scott
    morsario Guest
    Thanks for the detailed reply. I am not really after huge power increasees, i onyl really brought the exhaust to give the car a good note, so i am not to worried about all the high performence stuff at this stage.
    I just wanted to make sure first that the lack of back pressure is going to cause any damage to my engine?
  1. VT Sports Exhaust Help
    By zeep in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2006, 03:29 PM
  2. sports ryder
    By executive_power in forum General
    Last Post: 18-04-2006, 06:04 PM
  3. Sports Exhaust
    By tungsten_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-12-2005, 01:33 PM
  4. Vs Sports Exhaust
    By harvs01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2005, 08:06 PM
  5. VT sports exhausts
    By VT Power in forum V6 Development And Modification
    Last Post: 27-07-2005, 12:07 AM
