On the drivers side inner guard in the engine bay, there is a dent there...what the hell is it for? It looks bloody horrible and I think I will pull it out and smooth it over when I do up my bay. Somebody said they think it was to make it easier to change plugs on a V8 or something?
there was a discussion about this a year or so ago nd someone posted a pic of the Opel senator (which is what commodores are copied off) the air cleaner comes out of the engin on the drivers side and the dent is for the funnel to clear it.
I believe its for clearance of the a/c compressor.
ari666 is right, holden didnt change the dies when they pressed the inner guards.
cheers
Scott
i could be wrong
but i doubt it.
lol, that thing is frikken huge! my compressor was half that size. anyways i tried finding the pic of the opel air cleaner assembly but it seems 'just commodores' dont like archived threads :S
It was huge and it worked better than the a/c in my vt untill i ripped it all out to put a stupid chev in there and couldnt get brackets to suitthe bad bit about it was it took all the 253's power to run the bastard!
This is a pic of the Opel bay
Power is measured in DECIBEL
YouTube - Cold Airco
Its the Harrison A6 pump,use on many many GM cars:early Commodore,s Opel Monza/Senator,Chevrolet Camaro suburban and many many more,even Jaguar and Mercedes used that compressor.
Thats my Monza with the same huge heavy compressor as on that old carby holden V8.
I think its funny if its because of the Opel Air filter. Wouldn't it have been a hell of a lot easier to change the air filter setup than dent the car? I like the aircon explanation better haha. Either way, when I do up the engine bay I think I will pull the dent out anyway. :-) Cheers for the comments.
pull it or bog it, your choice, i hate seeing the dent in commys in car mags, it looks really dodge when they have a really clean engine bay, no wiring or nothing and this fat dint in the strut
Bog it?! No thanks. That'd crack and fall out before the engine was run in! I'll be pulling it out haha
a few quick taps with a hammer would sort it right out. THEN you can bog it![]()
or a mega size paintless dent puller, using a plunger
yeah, have you seen the paintless dent puller on here... modify that, get a toilet plunger and fill it with hot glue, put it on the dent and PULL
*facepalm* Why wouldn't you just do it the same way they fx hail damage and weld some little lugs on, heat it lightly and pull out on those. Toilet plunger? haha
cos you can hit it with a hammer from inside the wheel arch?!? no welding, no toilet plunger/glue.
done
Haha that shut everybody up. That's a great idea and I'll be employing that...however to get the right shape at the end I'll be pulling as much of it out as possible because I want as little bog in the engine bay as I can get away with. :-)
a good ball pene hammer and a little patience and you might get it so you dont need any bog![]()
the skirts has alot of strength in it,
you will have to shrink it as it will be streched from the dents shape
with mine i cut lines lines in it to remove some metal and welded it back together
although its a vl it had the same dent/s
My Rides
Project VEE EL
Yamaha YZ250F
My 'other ride'
The Aussie PackMule
SA JustCommodore Section
Now thats a nice engine bay. Nice work! *claps*
