Results 1 to 10 of 10
Thread: Vk 5lt 134 Build
    mertle Guest
    Hi there everyone
    I just bought a VK 5lt and just have a few questions?
    It's the 134 special factory optioned model, does this make it worth much?
    It's in good cond,, not a spot of rust, and the interior is good too.
    How much should I pay for a replacement blinker arm?
    Anything i should know about it? probs etc?
    The engine had a rebuild 50,000 k's ago and is very sound. It's on gas too.
    Thanks for any help here, it's the first vk that i have bought.
    Kerri
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    m8
    all VK's came with a manufacturing 'pack' - BT1, 134,234,
    a 134 pack is just an 8VK69 sedan with 5 litre 4 speed 4wheels discs
    as standard and then you add c60 (Aircon) plus AG5 (2 external mirrors)
    etc etc
    so really, not sumfing special about...just what was available from Holdens at the time..
    if looked after, will go ...oh 'bout another 100,000ks at least
    nothing really went wrong with these, if not abused...
    hth
    Smitty
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    OSL-060's Avatar
    OSL-060 is offline Banned
    Dec 2003
    SE QLD
    Can't really top Smitty's reply but I can agree and add a few more VK option codes.
    A8Q- Executive
    XW4- Vacationer 84'
    XY8- Vacationer 85'
    A9L- Model option - Commodore SS Group A (only 500 units made)
    T5G- Manual Transmission - Borg Warner 5 speed (optional on A9L Group A SS Package)
    V5H- 5.0L 122kW (eng. prefix - VZ)
    V5H- 4.9L 122kW (eng. prefix - VB)
    LV2- 4.9L 117kW (eng. prefix - VA)
    V7X- 4.9L 122kW (eng. prefix - VG)
    A9L- 4.9L 196kW (eng. prefix - VC) (A9L) is the SS Group A power unit, however on the body option plate it is listed as LV2
    8VK- Base Optioned 19 after code is Sedan 35 is a wagon.
    8VL Medium level optioned 19 after code is Sedan 35 is a wagon
    8VX Calais. 19 after code is sedan. Was not avail as Station Wagon.
    CF5- Sunroof
    DG2- Electric mirrors
    JM8- Rear Disc brakes
    K30- Cruise control
    N23- 82 Ltr tank
    XT8- Leather trim
    FE2- Factory lowered suspension
    BT1- Police Vehicle
    Jake
    mertle Guest
    Thanks for the replies I have more info about it, aparently according to the commodore aniversary book, most of what is below, apart from the gas, was factory fitted as part of the 134?
    VK Commodore
    5 Litre Re-Con 1998 Approx 50 000km old (180 hp at the rear wheels on gas)
    L34 heads, Extractors and exhaust 12 months old , Mild cam, balanced,standards Rochester 4 Brl Carb Stelite valves
    Duel fuel- City driving on gas 300km per 65 litres of gas (25-30 bucks)
    M21 4 speed (Bearing overhaul just done)
    New clutch (fly wheel machined)
    LSD
    FE2 Suspension
    Power steering
    4 wheel disc brakes
    Air conditioned
    alarm , central locking.
    Interior like new (cloth seats always covered)
    Body -No rust at all anywhere!!!
    I will see if i can get the book tomorrow and list what commodore says too,
    thanks again, Kerri
    Grantis1976 Guest
    All what they said, plus your indicator arm, available off the shelf at all leading auto stores ( autobarn, repco, supercheap etc. ) for around the $45 mark
    Good Luck !!!
    slot shop Guest
    Default 134 Pack
    Hi there,
    Stumbled across this old thread in google.
    I owned a 134 pack from new when I lived in Adelaide.
    A few features not mentioned above:
    HDT High Energy Ignigtion
    Heavy Duty Radiator
    1" Master Cylinder bore (std15/16")
    Heavy Duty Front Sway Bar
    HDT Heads
    Torquer Inlet Manifold (spelling)
    Larger Brakes front and rear
    No rear sway bar
    H/Duty Gas Shocks
    Cold Air Intake
    Hope this helps
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    slot shop Guest
    Default 134 Pack
    Howdy Boona,
    No, I used to have the car serviced by Road & Track in Adelaide, he ended up buying one too as he so so impressed by the bang for buck, cheap insurance etc. He ended up fitting a std 6 cyl bar to the rear of his, but said it made little difference.
    From memory the front bar was super heavy, 27mm comes to mind, but hey, it was 20 odd years ago
    VH SL/E 5.0
    Nov 2009
    Quote Originally Posted by sabacannon View Post
    Hey Kerri did you buy the red one recently from adelaide, i was looking for a 134 pack. I just bought another 134 pack in adelaide as well, needs a bit of work but they pretty much came out with a bit of work done to the motor.. They'll be worth alot more in a few more years once put back to excelent condition, worth the buy...
    Dude, this thread is 6 1/2 years old, doubt you will get a reply from Kerri.
    VK commodoe 134pack
    Nov 2010
    Liverpool
    haha, sorry man, didn't see the date, and i haven't been back on to delete it...
  1. VT HSV Build No 1
    By ephect in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-01-2010, 09:51 AM
  2. v8 vr build up
    By franzinkin in forum VR - VS
    Last Post: 20-12-2007, 04:46 PM
  3. VH 202 - First car build
    By Da_Blak_Ravn in forum VB - VC - VH - VK
    Last Post: 22-04-2007, 08:26 PM
  4. RE-build
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-03-2006, 11:20 AM
  5. to build or not to build
    Last Post: 24-08-2005, 02:44 AM
