Results 1 to 12 of 12
Thread: From 253/308 to 304
    Kirbs's Avatar
    Kirbs is offline L plater
    96 VS Executive S2
    Mar 2009
    Default From 253/308 to 304
    Hey guys, I want an old girl but I want a 304 in her. I can't be bothered with the hassle of converting a 202 to 304, So I am planning on buying a 253 or 308 and putting the injected engine in so I don't have to change the box/diff/springs/radiator etc. If I were to change the 308/253 out, I would need to get new wiring/ecu and new fuel lines etc right? Reason I want 304 is because of fuel costs and I am wanting to stroke it to 355, So it would be alot easier to use a VR/VS 304 as they are allready milled out.
    Quote Originally Posted by levymetal View Post
    what a coincidence! the only way i can get my 2 year old son to sleep is if he's in the front seat of the car, no child seat, no seatbelt, and i'm doing 250km/h down the mornington peninsula freeway.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    whats the question? would you need a loom? if so then yes, you will. and yes, you will need a fuel return line.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Plan on changing the box too. Almost all (if not all) 253's were drilled to a trimatic stud pattern to suit the trimatic auto or aussie 4 sp. You can build a trimatic to be strong enough behind a efi motor but the aussie boxes were marginal at best and won't handle the power.
    All EFI blocks were drilled to the chev "turbo" pattern and open you up to a heap of other transmission options. Grafting the wiring loom into the stock electrics isn't hard and been covered a heap of times before. You can save yourself some grief in the fuel system by raiding a EFI VL and getting the fuel lines and tank that has a EFI pump all integrated.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    You know that mid 85 onwards and all VL V8s are 304s right?
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by STEALTHY™ View Post
    Me or Kirbs???
    Reaper
    Reapers Black VP SS
    VH SS
    May 2009
    Toowoomba, Qld
    true, but VK 308 or 304, were both aussie/trimatic pattern
    STEALTHY™'s Avatar
    Jan 2005
    Me or Kirbs???
    Reaper
    kirbs, i would have quoted you if i meant you (but i'm sure you knew )
    cheers sexy
    Kirbs's Avatar
    96 VS Executive S2
    Mar 2009
    Reaper
    Yeah, Im planning on getting a T5 box and the crossmember from castlemine rod shop. Could I get the tank out of a VN or VS instead?
    Quote Originally Posted by ari666 View Post
    Yes, I know I'd need the loom but main question was would I need an ECU and stuff because im changing to injected. I'm 90% sure you do but just not sure.
    Yeah man.
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by Kirbs View Post
    yep, not much point putting the loom in without the pooter to run it
    Reaper's Avatar
    Aug 2004
    Yeah man.
    Pretty sure the VN/S ones are significantly different. VL is a straight forward bolt up job and they are very cheaply available.
    Add another 10% to that one - you want efi then you will need the ECU.
    Reaper
    Reapers Black VP SS
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    Quote Originally Posted by v8commy View Post
    yes but some vl v8s had t350 or t400 instead of trimatic
    Thats only the VL Director, had a 4 speed TH tranny. All Vl V8s factory had trimatic. Only time you would get a th350/th400 if someone put it in there.
