Results 1 to 11 of 11
Thread: vn diff into vh sle
    Vh sle 5ltr 83
    Mar 2008
    Default vn diff into vh sle
    hey guys wondering if i can fit a vn to vs live axle in my car because at pick a part all the vl ones are gone and also can i use a ford el gear and pinion 3.45 ratio on the vn diff?
    thanks also im running vh sle stock rims with 205's so there only stockys
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    Vh sle 5ltr 83
    Mar 2008
    Vh sle 5ltr 83
    Mar 2008
    vk calais 5.0
    Mar 2009
    reynella sa
    Quote Originally Posted by benny999 View Post
    ah cool just gotta look for a cheap set of 3.45 gears for a vn/vs diff
    ahh you mean for vlv8 vlt or vn-vt centre
    Vh sle 5ltr 83
    Mar 2008
    vk calais 5.0
    Mar 2009
    reynella sa
    if your changing it get a vt bosster and do the upgrade later if you have to
    Vh sle 5ltr 83
    Mar 2008
    vn diff in my car no dramas used a vn tailshaft cut and welded it goes like a beauty
    VH SS
    May 2009
    Toowoomba, Qld
    just be aware, that whilst VN-VS diffs will fit into earlier models they are wider
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    check this thread diff, all you need to know
    in short the answer is yes. it will bolt staight in and yes the Ford gears will fit as they come from the same diff (BW78)
    however, the VN diff is 52mm wider then your VH diff so the wheels will stick out of the gaurds, the wheel track will be all wrong and won't pass inspection unless you get some real odd wheel offset, much like a front wheel drive car so basically you would need to get the diff shortened. for the driveshaft you would need to use the rear section of a VN driveshaft fitted to the front half of your current driveshaft at the CV joint.
    if your currrent diff is a drum brake setup you will also need the handbrake cable as the cables are different between drum and disk brake configuration if memory serves me correctly.
    what is the reason for the upgrade? there are 3.55 gears avail for the large salisbury and there is a crowd that does a 4spider LSD unit to suit the large sals to replace the standard 2 spider LSD which was the weakpoint of those diffs
    308 VH SL/E would a had 2.6:1 diff ratio, with 3.45 gears it should take off like a rocket. cruising revs with the trimatic might be a bit high though
    Body by Holden, Soul by Brock
    the Legend will live forever
    Vh sle 5ltr 83
    Mar 2008
    Quote Originally Posted by immortality View Post
    yeah all done i have stockies so tyres fit fine i had a sals 3.08 lsd and destroyed it then 2 2.60's and destroyed then so went for something stock a bit stronger and i like 3.08 till i put a 5spd or t700
  1. Changing vx diff do you have to unbolt the whole rear end or just the diff unit
    By H1GHROLLR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-11-2009, 06:35 PM
  2. whats the diff between the diff diffs?(wagon and sedan)
    By redrags in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-05-2009, 09:51 AM
  3. changing diff gears or full diff replace?
    By callum_88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-05-2009, 06:59 PM
  4. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  5. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
