Results 1 to 10 of 10
Thread: vh engine
    4.2 vt executive
    Aug 2009
    Default vh engine
    ive just bought a vh that has already be converted to buick v6 but now has no motor or box
    what i want to know is will an ecotech bolt in with the same k frame and gbox xmember. or what do you think will be a good engine for a toy it wont be a daily driver
    4.2 vt executive
    Aug 2009
    VH SS
    May 2009
    Toowoomba, Qld
    if it's already got a k-frame to suit a VN-VR V6, then Ecotec should bolt straight in, but it's probably easier to run a VN/VP engine as the ECM setup is a lot simpler
    4.2 vt executive
    Aug 2009
    wouldnt the ecotech wire up the same
    4.2 vt executive
    Aug 2009
    i want to put the eco tech in because i have a mean 4.2l vt that runs low 14s and in a lighter bodie with a bit more work it should be a hell of alot quicker and more fun. im just not sure if it would wire and bolt the same as the buick thats in it
    4.2 vt executive
    Aug 2009
    Black VK Calais 333 Pack
    Jul 2009
    Melbourne - SE
    Mate
    The ecotec wil bolt in now worries. Would you just not transfer the engine box and looms across from the donor car. I think you will need to deactivate the security system. There are companies that can modify your BCM or you can get an add on black box from V6 Conversions to override it.
    I used a VP loom and ECM with my VR V6 to get around the security system. I am not sure that the ecotec is compatible with the earlier model loom.
    I too would like to know cause I might upgrade to an ecotec in the future.
    Pete
    4.2 vt executive
    Aug 2009
    VS Calais & vh sl
    Dec 2006
    deception bay
    VS Calais & vh sl
    Dec 2006
    deception bay
    half the work is already done and it would go well with the stroker in it. just redo the wiring to suit the ecotech.
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. Upper Engine Cleaning on old Engine (Unopened)
    By Jesterarts in forum The Pub
    Last Post: 17-02-2010, 09:02 PM
  3. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  4. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
