Results 1 to 7 of 7
Thread: vk aircon blocked maybee???
    vk calais
    Jun 2009
    Default vk aircon blocked maybee???
    does anyone know if the vk air con system has an orifuse tube any where? or if it is suposed to have a pressure switch on it??? i tried to regas it and it just pressurised the high side and took on hardly any gas. im stumped???????????
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    did you post up the other day asking why your aircond didnt work?
    and if so, did you check your vac lines like i said?
    VT spac super6
    Nov 2008
    Riverton sa
    yes all a/c systems run a hi/low pressure switch..
    you need to ad approx 250grams to the high side and then run the car with ac on full and slowly let refriderant into the the low side not letting the pressure exceed 300kpa for safety..
    youll struggle to fill the system without it running
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    VH SS
    May 2009
    Toowoomba, Qld
    you really should be charging the system through the low side! Could be half your problem. By going through the high side, not only is it unlikely that you will get the full charge in, but you also risk filling the compressor with liquid - BANG!
    If you vac the system down properly, you should get most of the charge in through the low side with A/C off. If not start the engine, A/C on and draw the remaining charge through the low side, whilst watching your gauges for overpressure.
    VT spac super6
    Nov 2008
    Riverton sa
    you do an initial charge through the high side, allow it to "boil off" rotate the compressor by hand and make sure its free then run the system
    thats what the courses are teaching
    VH SS
    May 2009
    Toowoomba, Qld
    mmm.... strange.
    when I got my accreditation we were told to charge through the low side only (granted that was some years ago) seems like a lot safer & simpler method.
    If you get it wrong charging through the high side, you risk stuffing the compressor - and I've seen it happen...
  1. Please help, VT V6 blocked vents, where to look next?
    By jonnydico in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2009, 06:34 PM
  2. blocked aircon drain - leaking in the car on drivers side
    By dandandaniel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2008, 07:10 PM
  3. blocked nose
    By tmaybz in forum Jokes/Humour
    Last Post: 06-11-2007, 06:13 AM
  4. blocked aircon drain - leaking in the car on drivers side VR
    Last Post: 24-12-2006, 05:42 PM
  5. VT aircon slowly becomes blocked while driving
    By DJT_1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2006, 01:01 PM
