Results 1 to 2 of 2
Thread: m21 4 speed
    VE , hg premier
    Sep 2009
    Default m21 4 speed
    hi
    ive got a m21 4 speed behind a 308
    i un-bolted the rear of the tail shaft from the diff
    when i started the car in nuteral without the clutch on the shaft spun. is this ment to happen??
    what could the problem be???
    cheers
    [ENEMY.8]
    VS v6 manual (Daily)
    HG PREMIER 350 (IN PROGRESS)
    VK WAGON 308 (FOR SALE)
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    The output shaft will spin in neutral but only when it has no or very little resistance. Im guessing that you've had the gearbox in and have had the car idling in neutral with the tailshaft attached and no problems? And even with the clutch disengaged it still has that little bit of drag to spin the gearbox when it has no talishaft.
    Then id say you you have nothing to worry about.
  1. Replaced Cluster and Speed Sensor, still won't show speed - only in ALDL
    By VS Omega in forum Electrical Wiring / Questions
    Last Post: 24-04-2009, 06:39 PM
  2. 4 Speed Auto VS 6 Speed Manual?
    By Wicked_D in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-03-2007, 02:09 PM
  3. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    By quick202 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 11:12 PM
  4. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    Last Post: 05-10-2005, 11:01 PM
  5. digital speed read out in VS with speed alert
    By vs0001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 06:09 AM
