G'day,
I've got a VH wagon (it was a 202 & M20) but now has 308 and trimatic. I've just put in another dash with a tachometer but I'm not sure how to wire it .. can anyone help? Is there a wire that comes out of the 6 cyl harness on the firewall side I can connect to?
And does anyone have any suggestions for swaping the starter? The solenoid is starting to go and I thought a replacement would be easy but there's no room at all. the power steer lines are in the way, the Pacemakers are in the way, is the easiest way just to drop the steering rack?
Cheers fellas.
there should be a really fat pink wire to the coil with a thin black one in the same loom. the thin black is tacho, the pink is ignition+
