Hey all, I want to change the door locks in my VC wagon to the VK style ones.
The VC have the button that pushes in from the top near the window to lock the door. These are very easy to break into with a piece of packing strap, so I was thinking of changing the locks to the VK style ones where they are a slide in the door trim themselves. I figure it couldn't be too hard as the doors are basically the same?
I changed my VK pop ups to slide locks (earlier VK's had the pop up ones too). Was only about a month ago I changed them but can't remember exactly. But ya need the actual plastic slide lock, the rod, and the plastic pivot point thing....oh and door trims to suit, just change those over and I rekon that was it.
But really it doesn't make it much more safer, there is another way to unlock them (even the slide locks), but that's fixed with those metal plates which sit in ur doors....so chuck some of those in too.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
