Results 1 to 8 of 8
Thread: VK MC6 to M76 Conversion
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Post VK MC6 to M76 Conversion
    HI
    Just thought id put up the few minor differences between the Mc6 Phillipino and M76 Borgwarner when your doing a conversion like i did.....
    -Speedo cable- completely different at gearbox end.
    -Tailshaft- front half is shorter, rear half is identical.
    -Clutch dust cover- just simply different.
    -Lower gear boot.
    -Upper gear boot- (can still use the MC6 one though)
    -The top boot you see can be used with either gearbox.
    -And obviously the gearstick is different
    -Gearstick knob- sounds stupid to add but the thread sizes are completely different and i didnt have a suitable gear knob for it.
    All the other stuff is the same eg.
    -Clutch
    -Gearbox mount/ cross member.
    -The plate riveted onto the transmission tunnel.
    -Clutch cable
    -Lower bell housing cover.
    -center console etc etc
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    I also done this conversion when I had my VK. Sounds spot on to me, and the gear knob is a good mention, the M76 ones seem to rare as hens teeth unless you go aftermarket.
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
    VS ute
    Jan 2010
    townsville
    i have a Borg Warner M76 in my vk. how ever i dont have speedo cable. any idea where i can get one? cheers
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    I would first check a local wrecker as i know there is a vk with a 5 speed at my wreckers. Next time i have a look under my car i check what the prefix on the sticker on its speedo cable is so if you see one on ebay you can identify it easier.
    VH Commodore
    Jan 2010
    VS ute
    Jan 2010
    townsville
    cheers for the replies guys. i havent found any in wrecker up here in townsville. any chance you could get the number sometime soon mate? i will continue my search
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    It appears the part with the sticker on it is under the dash will have look soon...............
    VS ute
    Jan 2010
    townsville
    Quote Originally Posted by VK SL 202 View Post
    cheers mate, greatly appreciated
  1. Man conversion-cruise control, will the auto cruise control work on manual conversion
    By pjdm1980 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 12:25 PM
  2. Vy Gas Conversion
    By Tiger28 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-03-2009, 07:32 PM
  3. 202 to 308 Conversion
    By VH_Commie in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-12-2007, 10:45 AM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
Tags for this Thread
