Results 1 to 15 of 15
Thread: vk problems blowing smoke running to ritch
    vt calais
    Jan 2010
    Default vk problems blowing smoke running to ritch
    my vk v6 is blowing smoke you can smell petrol not oil running rough and wen it hits da red line it chokes changed spark plugs leads oil ran injector cleaner through it is better but now how do i make sure its not running 2 ritch on fuel and running smoother
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    vt calais
    Jan 2010
    vk calais 5.0
    Mar 2009
    reynella sa
    distributor where the ignition leads plug onto undo the clips on that have a look at the terminals inside the cap and the rotor button its in the middile pull it off and check that out aswell
    vt calais
    Jan 2010
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    do the cap and rotor together. you would be surprised how long they sit on a motor for before they finally get swapped out. Just make sure everything goes back together how u had it and all should be sweet. ive changed a cap n rotor in under 5 mins.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    vk calais
    Jan 2010
    dude wot da?????? has it got one red or blue rocker cover or two grey rocker covers, because if it is a V6 it will have 2 grey covers and it wont have a distributer cap or rotor button, it will run coil packs. It will also choke or pull brake when it hits the limiter (THATS WHY THE LIMITER IS THERE, its more or less saying hey stupid bakoff or change gears or im gunna hurt your wallet)...............If its got a red or blue rocker cover then it aint a V6 its an inline 6, but to my knowledge it inline 6's dont have a rev limiter, this could mean that you are just reving it to hard and it is VALVE BOUNCING, if you got more question ask!!!!!!!
    vt calais
    Jan 2010
    cool thx for the ad vice will change both its a red top moter any more suggestions be sure to add and will post if a sucess
    vt calais
    Jan 2010
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    On a VK??, i thought VK's only had a Black 3.3L I6 carby, Black 3.3L I6 EFI and Black 5L V8 Carby???
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    ari666's Avatar
    1966 impala
    Mar 2009
    vt calais
    Jan 2010
    85 VK SL - 79 VB 253
    Jun 2009
    NSW
    Champ, do yourself a favour and purchase a Gregorys manual for it.
    Number 222 covers EFI and carbed 6 cyl VK's.
    Put it in the dunny on top of the Ralph mags. Read until your head hurts, then turn to the Ralphs for motivation.
  15. #15
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by vk3552nv View Post
    I know EST has a Rev limit of 5900 rpm so it doesnt explode and im guessing the EFI one would have one around that mark too.
    "my vk v6 is blowing smoke you can smell petrol not oil running rough and wen it hits da red line it chokes changed spark plugs leads oil ran injector cleaner through it is better but now how do i make sure its not running 2 ritch on fuel and running smoother"
    In a Stockie the red line is there for a reason.....................
  1. blowing smoke and oil
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 30-10-2009, 05:36 PM
  2. blowing smoke
    By mark&sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2007, 06:18 PM
  3. vs blowing smoke
    By lexcedore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2006, 11:08 AM
  4. Blowing smoke
    By minimefx in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-07-2006, 09:00 AM
  5. VR Blowing Smoke
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 10:19 AM
