Results 1 to 14 of 14
Thread: vk 308 dual fuel not running on petrol?
    vk 5 litre 308/ 4 speed manual
    Jan 2010
    Default vk 308 dual fuel not running on petrol?
    hey, got a vk with a 308 carby in it. Used to run on petrol fine but i have been running it on gas for a month or so straight. And now it won't start on petrol. Even if i'm driving and i switch it over it just doesn't do anything, like it's not getting any fuel. Any ideas. I'm lost. Cheers.
    Paiste402's Avatar
    Paiste402 is offline My workin on the car face
    1992 EB Fairmont Ghia
    Oct 2007
    Normanville SA
    make sure the pump is still working, first thing to check. if there is fuel then it has to do with the carby. let us know mate.
    Quote Originally Posted by <TVR-161> View Post
    yeah vts are becoming the new vn here, seing plenty with rear stockies, front chromies towing invisible caravans.
    Jan 2010
    don't mean to round stupid but how do i check if the fuel pump is working lol and where is it?
    Paiste402's Avatar
    Oct 2007
    Normanville SA
    haha u dont sound stupid mate. its down on the drivers side on the underside of the motor, infront yet below the extractors i believe. follow the fuel line to the carb and take it off at the carb. Get a bowl and sit the hose in there and get a mate to turn the motor over and look for fuel to come out the hose. Thats how i know its done
    vk calais
    Jan 2010
    g'day
    please keep in mind that late vk's run an intank pump, if you take off the fuse and relay cover and it has a relay for fuel pump its electric, if so get someone to crank engine over while you tap the tank with a rubber mallet, it SHOULD fire up, but by no means a fix the pump must be changed...................
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    edit* ooh got beaten to this post:
    (in regards to paists post) yep, thats how i would do it.
    i would think the first place to look if no fuel is a dud filter, then move on to the fuel pump. using paist's process
    if it has electric fuel pump then its a different story though... mine had factory electric pump. no mechanical. it also died which meant buying an after market carter black.
    stick your head down the bottom of drivers side just behind the timing cover and let us know what you see down there.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Why not tip a bit of fuel down the throat of the carby, turn her over and see if she fires? Don't go crazy with the fuel tho lol.
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    i think yous are forgetting to check the switch i have a hq 308 duel fuel switch was ****ed meaning no pettie changed the switch now it gets both
    ari666's Avatar
    1966 impala
    Mar 2009
    ah yes, well spotted, you mean the switch that will turn the petrol solenoid on, right? yup check the solenoid.
    vk calais 5.0
    Mar 2009
    reynella sa
    Quote Originally Posted by ari666 View Post
    exactly right as always
    commodore vk auto 3.3 everyday car
    Oct 2009
    When you switch to either gas or petrol you should be able to hear the solenoid for whichever you turn on make a distinct "click" sound.If there is no click heard then remove the wire connection and put a 12 volt independant power supply and touch the terminal and if you can't hear the click then the solenoid or wire/power supply is faulty.
    Oct 2009
    Just something else I have thought of is that after running on gas for a while and switching over to petrol allow a few seconds cranking as to fill the carb bowl if it has one.
    Jan 2010
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    check your fuel pumps working, change the fuel filter and get the injectors cleaned (use injector cleaner if you can get it to start)
    edit: i think you're meant to run it on a tank of petrol for every 5 tanks or so of LPG.
  1. VX 2001 Dual Fuel - Vibrates like crazy when driving on petrol
    By Barbie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2009, 06:05 PM
  2. DUAL FUEL rough idle on petrol, perfect on gas.
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2008, 03:30 PM
  3. VH 253 dual fuel running VERY poorly..ideas?
    By Rzeractor in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-04-2007, 10:02 PM
  4. Dual Fuel VS - Missfiring? on Petrol
    By Wojzilla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 12:24 PM
  5. vq statesman dual fuel v8 or petrol v6?
    By Mazzone_Child in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2005, 02:30 PM
Tags for this Thread
