Results 1 to 7 of 7
Thread: Leaking Door
    Blown-VH is offline VH Wagon
    VH SL Wagon
    Nov 2009
    Smile Leaking Door
    After it has rained i open the back door on the drivers side and water comes out. it sits at the bottom but just wondering how i can fix it. seals are okay so i dont know wat the problem is.. any thoughts?????????? would be a great help. cheers,
    VK sold.. VN3.8 and VX aclaim
    Aug 2009
    south auckland
    Change the window seal.. along the inside of the chrome along the window edging is a rubber seal... seals you proably cheaked are the door seals.. sealing the cabin when the door is shut... recheck the main window and quarter window seals... only way water can get inside the door unless you have rust/ holes in the door? does the door have the drain holes blocked?
    Floor it and swerve driving skool
    VH SL Wagon
    Nov 2009
    VH SS
    May 2009
    Toowoomba, Qld
    VH SL Wagon
    Nov 2009
    it is holding water at the bottom like so wen u open it it comes out. were are the drain holes??????? a little confused lol
    Aug 2009
    south auckland
    Run your fingers along the bottom of the door... 1 @ each end
    VH SL Wagon
    Nov 2009
    hey guys yeah just had a look at the drain holes look blocked i checked all four and thats the only one that looks it.. thanks for the tip guys. matt
  1. leaking water in the front by passenger door, any common leaks there
    By controlled chaos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-03-2012, 02:37 PM
  2. Door leaking water! Help!
    By fatboy15 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-04-2009, 02:30 AM
  3. [WA] Fs: Vt white drivers side door with window,door skin &mirror - $60 - perth
    By Timzo in forum Parts And Other Items For Sale
    Last Post: 12-01-2009, 07:59 PM
  4. Before I Go Taking The Door To Pieces!... Whats The Go With The Door Handle??
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-01-2006, 09:37 PM
  5. Replies: 2
    Last Post: 29-08-2005, 08:01 PM
