Results 1 to 15 of 15
Thread: what Gearbox??
    VE , hg premier
    Sep 2009
    Red face what Gearbox??
    ATM I have a m21 4speed gear box behind my 308
    I've have been told these are no good for draging??
    I am wanting to use this car as a drag and burnout car
    what are the turbo400 boxes like?
    I would mainly be looking for a powerglide I think
    [ENEMY.8]
    VS v6 manual (Daily)
    HG PREMIER 350 (IN PROGRESS)
    VK WAGON 308 (FOR SALE)
    VH Commodore
    Jan 2010
    Quote Originally Posted by hg premier View Post
    Heavy power sucking lead weights. A tricked Trimatic is good for 500HP. I dont know if a 2 speed would be good for burnouts.
    Ian
    v8commy is offline Banned
    vk calais 5.0
    Mar 2009
    reynella sa
    VH Commodore
    Jan 2010
    vk calais 5.0
    Mar 2009
    reynella sa
    Quote Originally Posted by IvanTheTerrible View Post
    I am.
    Ian
    i was actually talking to hg premier
    VE , hg premier
    Sep 2009
    do you reakon a trans joint will be able to give me a good deal on a swap for a trimatic??
    what am i looking for??
    what hi-stall??
    [ENEMY.8]
    vk calais 5.0
    Mar 2009
    reynella sa
    have you got a cam etc? if so get a 2500-2800 stall converter and if you find a good bloke hell do it for less than $1000 actuallyy ask ari666 hes in vic and he got his done cheap
    VE , hg premier
    Sep 2009
    as far as i know cam is stock so far but wouldnt be 100% sure
    [ENEMY.8]
    VH Commodore
    Jan 2010
    Quote Originally Posted by v8commy View Post
    I was backing you up. :-)
    vk calais 5.0
    Mar 2009
    reynella sa
    ok well thats what a stall is for to pick up the revs so that your matching your cam duration which means better take offs
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    no point putting in a stally unless you have a aftermarket cam. stock stall is fine for stock cams. when you upgrade your cam itll give you your estimated power range, ie. crane 286 is 2500-6500rpm, so i would be looking for a 2500-3000 stall converter. depending on how much fuel i wanted to waste.
    stock cams power is something silly like 1500-3000rpm, so stock stall is fine (i think someone mentioned 1600 but not sure)
    VE , hg premier
    Sep 2009
    Hey arri666 what gear boxes do you have ? Where did you ge it from and how much did it set you back?
    [ENEMY.8]
    ari666's Avatar
    1966 impala
    Mar 2009
    i only have the trimatic that is in my car, other than my 2 speed power glide . i like trimatics. simple and good for the HP my engine puts out. i sent it to the tranny guy to have it re-clutched and shift-kitted. twas' 800 for the reco and 400 for 2500 stally.
    if you are looking at drag racing, then i dunno. it depends on your power output bro. 308 ci displacement (my opinion) wont blow a trimatic that has been clutched properley. lets face it if you can get more than 400 HP from a 308 your doing pretty well. im talking NA and un stroked.
    if you are going 355-383 i wouldnt bother with trimatics, prolly look more at 400's but my tranny guy says powerglides are the ducks guts for 400+ HP sadly though they are gettin up there $$ wise.
    VE , hg premier
    Sep 2009
    Ok so it looks like of on the phone 2moro lookig for a joint that's gunna give me a good deal on a shiftkitd trimatic thx for all the help
    [ENEMY.8]
  15. #15
    VH Commodore
    Jan 2010
    Sunbury auto's used to be brilliant but I havnt used them in years. I have found a better bunch closer to my country location.
  1. which gearbox?
    By (CODEZ) in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-04-2009, 07:13 PM
  2. gearbox
    By mistermeena in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2008, 10:11 AM
  3. vs manual gearbox / rebuilt strengthed auto gearbox
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 14-12-2006, 07:51 PM
  4. What gearbox for vl.
    By bakes_eb in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-10-2005, 09:27 PM
  5. vr-vp gearbox
    By Wonderboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2005, 07:29 AM
