+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 26 to 50 of 55
Thread: Blue/black Dizzies And Stuff.
  1. #26
    burnz's Avatar
    burnz is offline dah dut dut da dah burnz Caprice
    2010 CRUZE Diesel
    Jun 2005
    springfield
    didn't the blue cam have a nylon gear drive
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
  2. #27
    matt69 Guest
    i chewed up 2 plastic gears on the end of my dizzy on my blue 202 vc till i got a metal one from the wreckers for $11.00
  3. #28
    03 VY V6 S2
    Oct 2005
    Does anyone have an advance curve for a stock black 202? Im doing an experiment an i need a basic advance curve for this engine.
  4. #29
    Wheelz60 Guest
    Exclamation Rotors VH-VK
    Further to bjturtle's comment.
    I've just made the change from the VK EST dissy to the VH HEI dissy.
    There is a difference in the rotors for each dissy.
    The rotor-shaft from the EST dissy is thinner than the HEI one.
    The top of the rotor looks to be the same.
    I dont know if there is multiple models of dissy in the VK.
    While in Supercheap, I looked at the parts catalogue, and the two have different part numbers.
    HTH.
  5. #30
    84 VK 3.3 Converted to EFI
    Nov 2005
    hey guys i need some i swaped the est for the hei but i need wiring help....
    84 VK 3.3 carb
  6. #31
    Nov 2005
  7. #32
    VK SL
    May 2006
    <<< 1) Make sure that you also get the blue HEI dizzy as you will need to use that, due to the vk running a computer for the timing (doesnt have vacuum advance). ... >>>
    is that aswell as something or meaning make sure i get a blue hei dizzy... sorry im new to working on cars
  8. #33
    HoldenMad's Avatar
    HoldenMad is offline Have spanner, can fix! HoldenMad Executive
    VT Acclaim
    Sep 2005
    Elizabeth South, SA
    On advice from many folks, I am switching from EST to HEI Dizzy.
    I have 2 questions.
    1) If I am not replacing the thermostat housing, where should the vacuum advance connect to?
    2) Do I leave the EST connected, or can I rip the box out and blank up the plug, or can I completely remove the whole EST loom?
  9. #34
    Pub247's Avatar
    Pub247 is offline Donating Member Pub247 W427 Pub247 W427 Pub247 W427
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Holdenmad just hook the vacum line up to any tvs on manifold or wherever and you can just unplug est unit.
  10. #35
    Crazymatt4546 Guest
    so when i put a weber 34adm on my 202 what exactly do you mean by "modifying the accelerator cable mount" does it just need to be bent or do i have to weld some kind of tag to it?
  11. #36
    RedVK Guest
    Question Engine running rough as at idle...
    Hey, I have an 85 VK 202 Black 5spd, runs okay, but i am at a loss as to where the hell my temp sensor is.... My E.S.T has been playing up recently, and i have no working display on the dash in relation to my engine temp... the engine idles at about 850, and under acceleration it feels almost like the donk is being flooded, resulting in a large power loss across the revs. Having had a quick scan across the forums, I see that this is a common problem... i'd like to see if i can fix it before it gets too ridiculous whatwith fuel prices... put it this way.... you would expect 42 Litres of 92RON to last at least more then 270 kays, but it didnt...
    HEEEEELP!!!
    (Cheers if ya can)
    (images would be great!!!)
  12. #37
    85 VK Berlina EFI
    Oct 2006
    Hey im new to justcommodores, i have a 1985 VK 202 EFI. When i saw this thread i thought i should ask wot colour is my motor coz it has a lot of red painted crap and so do a lot of EFI VK's but i thought they didnt come with red motors.
    Also this thread talks a lot about the carbie motors and how to more power and differences and stuff like that wot about the EFI how can i get more power.
    Thanx
  13. #38
    atrail308's Avatar
    atrail308 is offline RIP King of the Mountain atrail308 Executive
    V8 VH SL/E 308
    Mar 2006
    southside adelaide
    the EFI 202 was a black motor painted red, if you know what i mean...
    as for some tweaks to your 6, better intake and a mild cam should make some difference...
    No wah to that!
    Never late with ROB308...
  14. #39
    VK/SL 3.3l AUTO SED.
    Dec 2006
    Eastern Burbs Melb.
    Hey, HSKEV260R8. And anybody else interested.
    Have a look at the build date of the vehicles. You will find there is a commencement date for the fitting of airpumps to vehicles and includes the gallery along the top of the exhaust ports. I have a VK SL 3300 (202) that you can have the airpump from, if you want it(the pump still works). The pumps were fitted to all petrol powered vehicles as part of the ADR requirement of the time, prior to catalytic converters being mandated. Don't believe it achieved anything worthwhile though, except putting more money towards the fuel companies and causing horse power loss.
    No it's not NOS it's LPG
    Good Rep points are always welcome
  15. #40
    202 vh
    Feb 2007
    just wanted to know main difference with vh and vk carby?i got a vh and have a fully rebuilt vk carby will this work ok?
  16. #41
    vk202's Avatar
    vk202 is offline vkyos vk202 Executive
    vk 202
    Feb 2007
    sydney
    Default temp sensor
    hi mate the temp sensor is located near #6 spark plug ive put up a pic to show u were you should find it
    Attached Thumbnails Attached Thumbnails Blue/black Dizzies And Stuff.-5b1d_1.jpg
  17. #42
    86VL5spd is offline Repn RB 20-10 86VL5spd Executive
    R32 GTS-t 2 Door
    Dec 2003
    Blakeview,SA
    Hi ive got a VK and cant get my temp gague to work, was wondering which and where is the wire for it? lot of wires have been cut in engine bay?
    Also my dizzy hasnt been put in prply, was wondering how to set it up correctly coz for it to run nice i have to turn it right into engine and it keeps breaking then vac hose off?
    Thanks Damo!!!
  18. #43
    commsirac is offline Banned commsirac Calais
    vx
    Aug 2007
    Default Plastic dizzy drives
    I refitted my electronic dizzy with a metal drive, but perhaps that wasnt the right thing to do. Not sure about the full story on these, but here are some things for consideration:
    As stated ^ previously, the gears "may" have been made out of plastic in order to protect the drive gear on the cam.
    I have heard of some problems occuring with missfires on electronic dizzys with the metal drive fitted between 6-7000rpm that is cured by fitting the nylon/plastic drive........dont ask me how or why....I dont know! (perhaps some type of resonance problem)
    Holden designed these parts with 200000km ~15 year lifespan in mind, so just like the speedo drive and driven gears these parts dont last much longer.
    Perhaps the best thing to do is to replace the plastic drive every 80000km or ten years.
  19. #44
    VH + VK Gas Cars
    May 2004
    I think it should be mentioned that the VK varajet carburettor does not have a vacuum advance port to attach the VH HEI distributor to (only port available is below butterfly and 'constant' vacuum). It appears that I will now have to source an earlier version with the port or somehow modify the VK varajet model (drill hole)?
    I am happy to take further advice on this.
    Update:
    In speaking with a carburettor shop the VK carburettor has to be drilled and then fitted with a Holden Camira Base. I chose to replace the carburettor with a VH model.
  20. #45
    VK
    Feb 2008
    All you do is pull out the EST dizzy, and drop in a blue HEI dizzy. The pink wire stays connected to the + side of the coil, and the 2 wires from the HEI one hook onto the coil too. It's as easy as that. There is a brown wire in the VK that hooks onto the coil neg terminal for the tacho.
    My question is this, I have the donor car with the HEI, I have my car with the EST.
    Do I need to static time the engine first?
    Or do I just throw salt over my shoulder and pull out the EST dizzy and plop in the HEI?
  21. #46
    VK vacationer station wagon
    Feb 2009
    Default periodic vibration
    i own a vk wagon with a black motor, at a certain point it developes a vibration througout the cari i tried changing from the EST ignition to HEI but had a large amont of problems so changed back to the EST unit. I have also tried other EST units with no success and rebuit the Varajet 2 carby twice. What could the cause of this be? any help would be appreciated
  22. #47
    VK Executive
    Jul 2008
    Default cranks
    This might be a bit off topic but did the 173 (3.0inch stroke) blue motor crank get any treatment to lift its torsional vibration up the rev range same as the 3.3 cranks (thanks to the extra counter weights). or is the 2.8 blue crank the same as the 173 red crank ??
    Thanks
    Back on topic I have spent the last few days fitting and experimenting with a MSD BTM #6462. I used the EST crank trigger and EST dizzy + rotor with the MSD taking over the timing from the EST computer. It didnt work for me, it detonated its rings out on my turbo but with a std VK est it may be a good upgrade to get a bit extra out of the 3.3 varajet combo. I would think any of the 6ALs out there would wire and run the same as the BTM Im using.
    I removed the crank trigger and EST dizzy + rotor and dropped in a VH bosch electronic distributer I removed the module and wired the pickup wires from the dizzys coil (opposite to the std setting) to the magnetic pickup on the MSD. This works better but I still cant get any adjustment. Turning the dizzy seems to do nothing to alter the timing.
    My best result so far has been by not using the magnetic pickup on the MSD but by removing the green wire from the coil and connecting it to the white wire on the MSD. Then the pinkish wire from the dizzy (+ve on the coil) gets hooked in with the red wire and the ignition +ve wire from the loom.
    Ill still tuning so Ill update if I find anything interesting out.
    Next day: I removed the module from the Bosch dizzy along with the two wires that normally go to the coil. Hooked the Bosch's magnetic trigger up to the MSD's magnetic pickup but crossed them over ie small plug to large spade, big plug to small spade. I also removed all of the mechanical/centrificle advance from the blue motor dizzy so it is now locked with no advance. After an afternoon of testing I have the boost upto 11psi and have the retard set to 2 on the BTM. I set the inital static timing to 12degrees. The car is starting easier and is way better to get moving without having to ride the clutch. the lag is noticeably reduced. It pulls hard and faultless upto the 6000rpm rev limiter. It was hard to wipe the smiles of our faces as we put the car away tonight.
    VK Turbo build
    My Forum
    Email me
    Anyone can buy one. Its a lot harder to build your own..
  23. #48
    mightyredvc's Avatar
    mightyredvc is offline feel the fury mightyredvc Executive
    83 vh sl/x (mid build)
    Oct 2005
    hobart
    Default weber carb
    hope this is the right place to post this...
    i fitted a weber 34 adm to my blue, made the adapter and everything my self, and was really happy with the results. more power, better economy, easier starting, all the good stuff.
    problem is it chewed through 3 throttle cables in 12 months. i can see the angle is wrong and all but i have no idea how to fix it. it mentioned in the start to the thread that the linkage needs modifying. how?
    what exactly do i need to do?
  24. #49
    82 VH Commodore 202
    Nov 2009
    Redcliffe, Western Australia / Wiluna, North Western Australia
    I have a VH 202 auto bluemotor, the HEI dizzy was broken i now have what i believe to be a redmotor standard vacuum advanced one in there which works fine, i was wondering where these three wires go and if they are related?
    Green i wired to the temp sensor and the brown i wired to the alternator, i have what i think is a vk thermostat housing which also has a temp sensor in it, should i wire this wire to that instead of the one near plug 6? or will the one near plug 6 work fine? i have a VC stage 2 dash installed without a tacho
    also i fitted a CAIN intake manifold and a 350 holley, i used the pipe from the side of the carb to the dizzy vacuum advance i copied this from the patrol that the holley was from, i don't have any EGR gear as i have extractors fitted, this is how i have put the rest of the vacuum pipes, there is a pipe on the baseplate of the carby but it has been clamped shut should i move any of my pipes there?
    i have no understanding of how the thermal vacuum switches work and at the moment they are bypassed if i need to use them how would i go about rigging them up, i also looped my pcv system back into itself, is this much of an issue?
    sorry for all the questions at once, any info is much appreciated
    1982 Holden VH Commodore 3.3L "Bluemotor" Exec. /// 1989 Suzuki Sierra 1.3L G13a SoftTop
  25. #50
    82 VH Commodore 202
    Nov 2009
    -----bump^
+ Reply to Thread
  1. wtf is this black stuff?
    By VSSPak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2006, 09:42 PM
  2. car spitting out black stuff
    By silvr6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2006, 01:32 PM
  3. black stuff coming out my exhaust? oil?
    By maccona35 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2006, 04:12 PM
  4. Black 202 Or Blue 202
    By The VHK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-04-2006, 05:44 PM
  5. Black Or Blue?
    By Kim in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-02-2004, 08:54 PM
