Hi all,
looking at a VK, police issue pursuit car from W.A
asking price is not to bad, body is straight with minimum rust, has a good interior, air, fan, wipers are not working, motor sounds ok. Car has been stored.
Model no: vk8vk19
body no : 186 350-a
trim : 0924-24x
paint : 1b109-d
eng: Lv2, M40, GU4
September 1985 build
Any information would be appreciated, would like to confirm details are correct. Thanks in advance for any info.
any links to it i love lookin at older model chase cars![]()
{H1GHROLLR} CHEMICALLY SUPERCHARGED A.K.A NITROUS FED R8 CLUBBY and {HYPED UP} TWIN TURBO VX SS DAILY
it's not on the net, heard of it through a friend, would love to have some pictures to post.
impressive use of caps, as mentioned i don't have any pic but wish i did. Will try to get some to make you happy.
Want to confirm numbers to make sure it is what I am told it is, all the pic's in the world aren't worth anything if the number's dont make sense.
Caps are worth sh%t, if you dont have a helpfull answer why even bother responding with sh%t all.
its just a pic, like many others.
the link to it is http://home.freeuk.com/jrknight/smileys/postpics.gif, just take that link and put it in IMG codes
soz mate. you will have to fish through the kids for a while.
there is a guy on here called SLE nut who has the decoding book. best send him a PM.
edit* found him: http://forums.justcommodores.com.au/...s/sl-enut.html
With the model code line, can't see BT1, denotes ex Police Pack option. But, have a look at the front door arm rests. A bit of a tell tale sign.
On police packs, the rear arm rests where also in the front doors.
Did all the police packs have Bt1 on the plates or just some of them and where was it stamped on the plate,cheers
Model no: vk8vk19 (8) = GM-H Australia Holden (K) = Luxry level - SL (19) = Body style 4 door
body no : 186 350-a
trim : 0924-24x (24x) = Cerulean vinyl with cloth seat inserts
paint : 1b109-d
eng: Lv2, M40, GU4 ( LV2) = 4.9litreBrock motor (M40) = ????? (GU4) = Heavy duty Salisbury LSD
Sorry I could not give you all the info but at least this will help you
Yes I brought a ex pursuit car back in 1986 and still have it today - depending on the price you have a very good start in performance wise already with some good gear - good money for Brocky mock up's
Corrections here. LV2 means 304 ci block not a brock spec. At the beginning of Feb 1985, Holden only made 304 ci motors due to Group A rules. The old 5 litre/308 code was L31. Only way to see if its a Brock spec is the engine number prefix.
M40 means the good ole 3 Speed Trimatic auto slush box
GU4 means 3.08:1 diff ratio not heavy duty Sals diff. All factory V8 VK's all had the 10 bolt Sals diff. You would have to get the build paper to see if its fitted with heavy duty internals, LSD.
does your dash tacho look like this with the extra ticks on the tacho? if so its a xpiggy dash & also does it have black pockets on the front doors
GEELONG PREMIERS 09
decided to pass on this, the car was advertised as..
COMMODORE 1985 VK SS
EX CHASER BROCK MOTOR AND INTERIOR
AUTO 17" RIMS POLICE BLUE STORAGE 5 YRS
MUST SELL NO REGO
$6000 O.N.O 0409487570
(as advertised in the GC Bulliten 13th Feburary)
maybe someone here is intersted
