Results 1 to 19 of 19
Thread: Brake pedal travel
    Snap-on's Avatar
    Snap-on is offline Boilermongrelin
    82 VH, 99 VT Wags, 03 VY S
    Apr 2008
    Brisbane, Northside
    Default Brake pedal travel
    Hey peoples,
    Just replaced the brake master cylinder today on my VH. The front discs are fine, new pads, rear drums are fine and has new drum cylinders. I bled the master cylinder before installation and then bled the system at each corner, two times.
    The problem I have is that the pedal travel is still about half way ie: You need to depress the brake pedal 50% of the way to the floor until the car starts to pull up.
    Question is: Is this normal with your cars? Or is my VH in need of more repairs?
    Cheers, Deano
    VT Ballin'
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    Did you replace the brake master cylinder with a new identical unit? Eg same diameter? Did you do anything to the booster or lines? I assume you're not loosing any fluid.
    "Please contact the Administrator if your date of birth has changed." JC Forum. Profile editor.
    Snap-on's Avatar
    Apr 2008
    Brisbane, Northside
    yep identical pbr replacement part, didn't even touch the booster lines and its holding fluid quite well. That's why I can't figure it out!
    VT Ballin'
    VY S pack & VP ute
    Jun 2008
    did you correctly prime the master cylinder, if you dont i do believe they get an air lock that you cant get out unless u take it out and do it on the bench
    Snap-on's Avatar
    Apr 2008
    Brisbane, Northside
    Yep sure did
    Quote Originally Posted by Snap-on View Post
    VT Ballin'
    vb sle
    Jan 2009
    adelaide
    probarly the booster the are pices of sh*# ive changed about 6 second hand ones and they are all the same leaking is it making a sucking noise?
    Holden S 2000
    Jan 2010
    Hey the best thing for you would be to go and see a mechanic person and ask them,becuase if you trying to fix that by yourself something mite go wrong.
    Snap-on's Avatar
    Apr 2008
    Brisbane, Northside
    Quote Originally Posted by leigh 7005 View Post
    Hmmm yeah im thinking this aswell cos the booster is rusty and old lol
    And yeah I was thinking about taking it to one those things, what do you call them - McKennocks?
    Any one else had this issue?
    VT Ballin'
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    soz for the late post, but TBH is sounds like your system still isnt bled properley. if your boosted is naff itll be really hard to depress the pedal, not free-paly for half.
    i dont mean to be a pain and you can ignore my advice, but you MUST start from the rear passenger side wheel first, as its the furtherst from the master cylinder. i went through this crap too, tried three times and no good, then one day it just worked.
    so start with the rear passenger side, stick a clear hose onto the bleed valve and lift it above the height of the master cylinder. pump your pedal a few times as normal (while the engine is running) then get your mate to release the valve quickly while you are depressed., it takes a few goes to make sure there are no bubbles in the clear hose you ran, but when you are a million per cent sure there are no bubbles, move on to the rear drivers side.
    itll waste a bunch of fluid so be ready for that.
    soz, but i am pretty sure if you give it one more go you will hit it
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i agree with ari666, you need to bleed the system again. a faulty booster results in a hard pedal (i have lots of experience with this particular fault )
    the other option is to take it to a brake shop and have it pressure bled. might cost a little bit but guarantied to sort the problem.
    for the next time you replace a MC, reconnect the brake line but leave em a little loose, then go to each caliper and squeeze the piston back in a little, this way it removes any air in the brake lines at the MC. wrap the whole area in rags to prevent getting it on the paint work. then tighten the fittings properly
    Body by Holden, Soul by Brock
    the Legend will live forever
    Commydoor's Avatar
    Commydoor is offline born in the FB era
    Vr Ss Blown
    Sep 2007
    Beresfield, NSW.
    sounds to me like they gave you the incorrect size rear wheel cylinders (larger bore diameter)
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by immortality View Post
    yet another really good idea im gonna use that. cant beleive i had never heard of it b4.
    vb sle
    Jan 2009
    adelaide
    so if the booster is stuffed itll be stiff i thought if the booster is stuffed youll hear a sucking noise corect me if im wrong?
    85 VK SL - 79 VB 253
    Jun 2009
    NSW
    Correct on both counts.
    A stuffed diaphragm in the booster will make a sucking noise and will affect the boosters ability to assist the master cylinder.
  15. #15
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You shouldn't pump up the pedal when bleeding, all that does is aerate the brake fluid.
    The best method is to leave the engine off, open the bleeder, push the pedal down, close the bleeder. Do that until there are no bubbles coming out. You don't need to raise the clear hose above the master cylinder either.
    Another thing, did you reset the brake switch on the side of the master cylinder? Undo it until you hear a click then do it up again.
    Visit my Facebook page
  16. #16
    Snap-on's Avatar
    Apr 2008
    Brisbane, Northside
    Thanks for all your input fellas! I'm gonna bleed the system again to see if it fixes the problem.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    What is the brake switch - the electrical plug? What will re setting it do?
    VT Ballin'
  17. #17
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    When the pedal goes too far it activates a brake warning light. There is a pin in the switch that goes into a groove in the piston and locks it about half way in the master cylinder. Undoing it until you hear the click will let the piston come back to it's proper position. Sometimes that is what causes a low pedal.
  18. #18
    vb sle
    Jan 2009
    adelaide
    ill try that 2 thanks
  19. #19
    Snap-on's Avatar
    Apr 2008
    Brisbane, Northside
    hmmm very interesting. I will have to try this too.
    VT Ballin'
  1. Put Manual Pedal Box In, Now Brake Pedal Is Stiff, Quick Replies Please
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2009, 09:01 PM
  2. VB to VT Brake upgrade with pedal box.
    By Grunthos in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-10-2008, 12:14 PM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. brake pedal question
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2006, 09:15 PM
  5. Low brake pedal.
    By edgar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2005, 12:25 AM
