Results 1 to 1 of 1
Thread: tvs valve - vacuum sensor VK
    VK Commodore
    Jan 2010
    Default tvs valve - vacuum sensor VK
    I own a VK 3.3 ltr efi. I have broken the xmas tree on top of the thermostat housing cant seem to find the part i need to replace it i have gone to all the retailers and even wreckers and cant get a straight answer from anyone. i have attached a photo of the part i need. if someone could tell me the name of the part and also were to find in victoria or even if i can bypass it somehow. or alternativly can i just block up the hoses to the dizzy, throttle body and to the other vacuum part at the back of the manifold. or will that effect idle/vacuum?
    Attached Thumbnails Attached Thumbnails tvs valve - vacuum sensor VK-p290110_17.36.jpg   tvs valve - vacuum sensor VK-p290110_17.35-02-.jpg
  1. Vk Vacuum sensor.
    By VK SL 3800 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-10-2009, 09:43 PM
  2. [QLD] WTD: LS1 TPS sensor and Idle Control Valve
    By BIG-EV in forum Swap / Wanted to Buy / Trade
    Last Post: 11-09-2009, 02:23 PM
  3. vacuum hose check valve location
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-10-2006, 01:54 PM
  4. Error 33 - MAP Sensor voltage high / vacuum leak
    By shaggerz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-10-2005, 09:06 AM
  5. Engine Vacuum and O2 Sensor Test
    By Motorsport in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2005, 11:56 AM
