Results 1 to 3 of 3
Thread: VK EFI Cam?
    VK Berlina/VX S Pac
    Jan 2010
    Central Coast
    Default VK EFI Cam?
    Ok, so I've read a few different things about the VK EFI motor on the net in regards to cams. Some people say you can some people say you can't.
    Basically I just want to know whether I can run a performance cam in my VK EFI, looking at going for a stage two?
    By the way it's an auto if that helps, but thinking of putting a 5 speed in later down the track.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if you get a computer freindly cam it will be ok if you want to go more aggressive youll need to swap out the ecu and stuff.lots of people go the delco ecu out of a vn or camira and use a camira ignition module on the vk electronic dizzy.bonus is you get rid of the flap airflow meter out of the intake at the same time giving you better intake flow.sammy had his torana running a 202 cammed and compression build with the delco was putting out the same power as a V6 on the delco just didnt have the same amount of torque as the v6
Tags for this Thread
