heater works well blows hot air at feet and demister but always cold air at face and side vents any ideas i have to vh's and both do the same
As I understand it that is the way they are designed so you have to manually turn off the vents in the middle using the side wheels.
yeah all that works but always blows cold to face even when on hot not sure why its my second car that is doing the same thing starting to think the are factory like this. if it blew hot and cold it would be great when i didnt want nothing to come thru id turn them off like u said.
Yeah I know what you mean. I have owned three VH's over the years and they have all been the same -it's a factory thing.... weird huh?
Did your VH come with an owners manual? You should checkit out they reckon it's all to do with this magical ventilation system.....
The Max Ellery service manual explains the heater operation, unfortunately that's just the way the VH heater system is designed to work. It's crap I know.
It will only blow hot air to the feet and/or demister.
I've been considering if it would be worth the trouble of fitting a VK/VL ventilation/heater system. There's a bit of work involved (including cutting a hole in the passenger side plenum, and covering the existing hole in the centre of the plenum) but at least that way you get a full functioning heater system and vacuum controls
easy to fix costs $5.53 - $5 for petrol 35 cents for matches
really i thought hot and cold could go where ever u wanted it my vc sle blows hot thru the face vents. im fanatical about everything working properly. maybe ill put a vc heater in or vk. cheers mate
if i knew that about the heaters i would have canned the heap i love my heaters and helps when u keep the chcks warm hey, i would mind having a look for an owners manual ill check ebay thanks for the info u can see the vh in my profile the pics are small ill take some new ones. its 2 pac black underneath aswell has everything u can think of replaced and the heater is as bodge as they come
i live near the macedon ranges its cold as and im looking for photos of all the air con piping thru the engine bay so i can put it all together i have 2 cars worth of pipes and stuff and no idea where it goes si if some1 could help would be great its a 6. cheers
i used to have a 6 wagon that blew hot at the face vents it was a vh one so i dono some one may have done something to it would like to know what
yer just trying to get it working properly and the air con half way through restoring a vh even the trouble 2pac underneath and painting everything and getting everything recod or new going to have a show car and no heater. what can i say typical holdens lol might just sell it and drive my daewoo
