Results 1 to 13 of 13
Thread: Vk Rear Suspension
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Default Vk Rear Suspension
    Ok, i have read all about having to get adjustable panhard rods when you lower you commodore but my VKs rear end has decided to sag recently (about 1.5 inches lower than normal), it has moved the diff over about 15mm to 20mm. Does this mean every time you hit a bump with standard springs the rear end is moving over like this?
    They are standard springs.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    lets imagine for a second that you had no springs at all in the rear. and on the buffer stops your rear passenger side wheel sticks out about 30mm then jacked up to 200mm off the ground, your wheel sticks out 30mm from the drivers side. then half your height and your wheels would be perfectly center.
    making sense?
    so however much you cut off your spring (or they just "sagged" of their own accord... whatever) expect that to be sticking out of the passenger side wheel. its like an arch. adjustable panhards just re-center your wheels for whatever new height you have decided to cut your springs to.
    but yes. the answer to your question is yes, everytime your wheels go up and down, they also go side to side due to solid axles and a panhard rod.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Could adapt up a watts linkage setup....we're thinkin bout doin that with our race car. Then no matter how far it goes up or down (to a certain extent), the wheels stay in the middle.
    Going to all the trouble to do that is prolly a bit o****ill for a street car tho.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by DANNY8 View Post
    I've thought about doing the same thing, but have since have sorted out the major bump steer issue I had with the back end. Plus it would need a mod plate etc, which I can't be bothered with. I've seen a couple of live axle street driven Commodores converted to watts link. Good setup. The V8 Supercars all run a watts linkage.
    but yeah back to the original post, the panhard rod system used on the Commodore is a very compromised system. The axle will move laterally over bumps in the road - causing 'bump steer' in the rear of the car. However an adjustable panhard rod improves the effect dramatically on a lowered car. My axle wasn't even far off centre after lowering, yet the back end used to jump/skip to the side when cornering over anything that wasn't a perfectly smooth surface. It induced unpredictable handling, really unsettled the car, sometimes it would throw the car into bad oversteer. I finally bit the bullet and fit an adjustable panhard rod (honestly didn't believe it would do much to rectify the problem as my axle was only off centre by a few mm). But the difference was amazing. I think what also helps is most of the adjustable panhard rods are constructed of a much heavier gauge material. The standard rod, when used in conjunction with more solid suspension bushes, I suspect flexes under load which gives a springback effect on the axle, which could account for the radical behaviour.
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by Darren_L View Post
    The adjustable panhard rod in our race car looked to be of good quality (good welds), but yeah the first time we used it, she bent. That's racing on the dirt, but was at the Port Augusta track which is a very hard surface.
    But yeah, just had to bend it back out and re-inforce it.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    I have been looking into a watts linkage rear end for my VK for my next project.
    Dare I say it or even think of it using falcon gear. They runa borgwarner diff same as a commodore so the diff hat swaps straight over, then its just a matter of measuring up mounting points and welding up some mounting brackets maybe modifying the arms off the falcon. I think when i finally get the time to do it I will have it done in a weekend quite easily.
    cheers
    scott
    vk commie
    Dec 2010
    hamitlon
    my vk commodore has been put on superlows but, the front is really low and the back is sitting up quite a bit still, i want to know what would be a legal way to have it sitting a bit lower without cutting my springs, also have heard about adjustable panhard rods but am just not sure if they are the trick ? can someone help me out cheers
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    You need to consult your design rules for your country ie in Aus its ADRs they specify the ride height your car is allowed to be, the lower the car the less suspension travel (unless major work is under taken) and the worse it can handle on bumps.
    You may also find your strut top mount/rubbers have sagged which will also cause the front to be lower than normal.
    scott
    VH SS
    May 2009
    Toowoomba, Qld
    Quote Originally Posted by vkcomie View Post
    you can get springs reset to the height you want, that might be the easiest way as opposed to trying different springs.
    an adjustable panhard rod is mandatory on a lowered live axle Commodore. You should definitely invest in one.
    vk commie
    Dec 2010
    hamitlon
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Hopefully theyll help you and not just rape your wallet like a lot of places do.
    VH SS
    May 2009
    Toowoomba, Qld
    ok, so i should go to suspension place and se if they can help
    suspension place if you want to buy another set of springs.
    however if you want yours reset, you'll need to go to a spring manufacturer, resetter. Resetting truck springs is big business, most also do car springs
    Mayne Springworks does them here in Qld, not sure about other states, but I'm sure the yellow pages will give you some ideas
LinkBacks (?)
  1. VP rear suspension
    By wagonist in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2009, 02:26 AM
  2. VZ Ute rear suspension ???
    By OZ38 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 31-03-2009, 12:23 AM
  3. VT/VX/VY/VZ - FE2 Rear Suspension
    By Kung-Foo-Kamel in forum Parts And Other Items For Sale
    Last Post: 12-12-2007, 10:27 PM
  4. rear suspension
    By domz_VT_like_no_other in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-04-2006, 02:17 PM
  5. suspension on the rear?
    By Bull in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2005, 06:52 PM
Tags for this Thread
