Results 1 to 14 of 14
Thread: Adjusting bonnet striker/jammed bonnet on VK
    Phantom WL Caprice 5.7 V8
    Feb 2009
    Default Adjusting bonnet striker/jammed bonnet on VK
    Hey all,
    We've got this VK we're doing up and we've got a case of the old 'bonnet doesn't open unless someone is pushing down on it' scenario...
    Now for those in the know, does the adjustment need to be made in the cable somehow, or the bonnet striker itself (or both). The cable seems to be doing it's job (although it has been removed and then put back on after painting) and I'm afraid to adjust the striker any tighter for fear we can't get the thing open at all. (Or does it need ot be much looser?)
    Has anyone had the same issues and come up with a solution as to what to try first?
    Thanks for any info or ideas!
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    The adjustment gets made to the bonnet striker itself.
    Grab a big arse spanner/shifter/multi-grips and loosen off the big nut slightly,
    Than use a flat head screwdriver to make the adjustments (screw it in or out)
    Hope that helps!
    Feb 2009
    Thanks mate, yeah I know 'how' to adjust it, just wanted to know if the issue of a sticking bonnet is a striker being too tight or too loose. Too tight and it may not pop open but too loose and there may not be enough resistance against the latch to release it.
    Just want people's experiences before I go tightening or loosening
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    the two rubber bumpers on the front of the rad support will provide you hours of entertainment. if they are up too high, itll lock the bonnet. just twist them by hand all the way down and see if that helps.
    i had mine too high and i had to hit the bonnet while pulling the bonnet lever at the same time... fonzie style
    Feb 2009
    yeah those adjustable bonnet stops aren't even on the car so it can't be them!
    (used to have a VL where'd you could hit the corner of the bonnet and it would pop up!
    Jan 2010
    Bendigo, Victoria
    I'd adjust the striker, worst comes to worst the bonnet won't open and you'll just have to manually do it
    If you do it with the grill out and without doing the nut back up stupidly tight, you can just unscrew it again until you can 'pop' it. If its too tight lay under the car and reach up and pull the cable manually while someone presses on the bonnet.
    I've had all sorts of stubborn bonnet catches, used to have a WB ute that regardless of how you adjusted the striker, you had to jump onto the bonnet to close the bloody thing.
    Feb 2009
    It's got a Brock front spoiler so there's no way in hell you can reach the cable from underneath (unless I had 3 elbows ) I'll take the grille out and see if I have good access and try the adjustment you suggested, bit by bit to see if I can get it spot on.
    Cheers fellas
    Jan 2010
    Bendigo, Victoria
    seen a guy break his arm looked like he had 2 elbows..... never seen 3 though, can't help you there!
    Good luck with the striker though.
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by neet_wagon View Post
    was he tryin' to adjust his bonnet?
    Jan 2010
    Bendigo, Victoria
    nah, was riding a pushy.
    ahh those were the days........... pfft f*%k riding, struggle to walk to the car to go to work!
    Hell, im not even the one driving!
    ari666's Avatar
    1966 impala
    Mar 2009
    anyway, back on topic. if you MUST adjust the striker i would say loosen, so the spring is taller.
    VTSS GEN3, VKSSA REP V8, VP BT1 V8
    Feb 2006
    darlington
    other thing to look at to could be, if the skin of the bonnet has broken away from the frame it will cause ur bonnet 2 shake and then throw ur striker out. thats the issue im having atm with mine.
    BAD COP!! NO DONUT!!
    Feb 2009
    cheers but the bonnet is tip top. It IS however slightly out of alignment so I reckon that could have something to do with it. Will go at it this weekend hopefully..
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    lol, you know that clean LS1 VL (H8FORD), well, he has the same problem... lol
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
  1. need help! bonnet latch is broken and cannot open bonnet!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2012, 11:10 AM
  2. Bonnet release cable snapped how do i open the bonnet
    By S-Pac_Sam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2010, 09:07 PM
  3. Bonnet Jammed
    By RunninWild in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2008, 09:35 PM
  4. Tightening bonnet hinge(body end, not bonnet end)
    By NOGEN 3 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-03-2007, 11:28 AM
  5. Adjusting bonnet length.
    By vnberlwagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2006, 07:30 PM
