Results 1 to 10 of 10
Thread: 6cyl to v8 engine swap
    vc 308/vs 3.8
    Feb 2010
    Default 6cyl to v8 engine swap
    need help have VC 3.3 blue motor, power steer, swapping to 308 out of HQ . swapped steel engine mounts that bolt to block for commodore v8 . still have rubber mounts that where out of HQ thought they where all the same . but engine mounts still do not line up. Still have original k frame, do I have to swap k frame for v8 commodore k frame?.
    DANNY8's Avatar
    DANNY8 is offline Yo Coooornflake!
    VT SS 5.0L, VK WAGZ 5.0L
    Apr 2004
    Port Pirie, South Australia
    Nah mate ya don't need to change the kframe's over. How isn't it lining up? Ya sure it just doesn't need to be moved back more or sumfin? They can be a tight squeeze gettin in sometimes.
    VP Executive R-spec
    Jan 2005
    You need a Commodore sump on it, you don't have the HQ sump on it still ?
    SL/ENUT's Avatar
    SL/ENUT is offline The SL/E Fanatic!
    VB SL/E 5L and VC SL/E 3.3L
    May 2004
    Burnie, Tasmania
    You need commodore engine mounts. I think the HQs are a little different.
    DANNY8's Avatar
    Apr 2004
    Quote Originally Posted by SL/ENUT View Post
    The metal ones are different which bolt to the motor, but the rubber ones are the same.
    Just searched the Kelpro website and the listing for 5.0L VC and WB are the same. It doesn't have listings for Kingswoods for some reason.
    vc 308/vs 3.8
    Feb 2010
    Quote Originally Posted by DANNY8 View Post
    thanks for your reply engine is sitting on mounts on mounts on k frame but the holes are about a 1 inch out of alignment on each side close but not close enough might have to take to them with a big hammer to get to line up.
    vc 308/vs 3.8
    Feb 2010
    Quote Originally Posted by greenfoam View Post
    yes I do have group A commodore sump and pickup on the engine..
    vc 308/vs 3.8
    Feb 2010
    turned the rubber mounts around and it lined up sweet. thank"s for your help.
    DANNY8's Avatar
    Apr 2004
    vkwalks39's Avatar
    vkwalks39 is offline NUCKING FUTS
    VK V8 / VH V8 / VR V8
    Sep 2007
    Stawell Vic
    Gday, im doing the same to my vk. the HQ engine mounts will put the engine back abit, it will be hard to move the dizzy around. If you using extractors the driver side will be tight fit but it will be fine. And, the power steering you will need a V8 one...I hope this help you, Cheers Jason
    MISSING
    WIFE AND DOG
    REWARD FOR DOG!!
LinkBacks (?)
  1. [QLD] 05' CR250 for manual 6cyl VL-VS - Swap/Trade
    By calais_304 in forum Swap / Wanted to Buy / Trade
    Last Post: 20-02-2009, 11:40 AM
  2. Vn Engine Swap -- Help :)
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2008, 09:31 PM
  3. vn-vt engine swap
    By jessiepal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2007, 07:59 AM
  4. VK 308 Berlina sedan, SWAP for VH 6cyl manual.
    By broderikb in forum Swap / Wanted to Buy / Trade
    Last Post: 10-07-2006, 06:59 PM
