Results 1 to 5 of 5
Thread: VK Viscous Clutch Fan
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Question VK Viscous Clutch Fan
    Ok, i have been informed that my VK is supposed to have a Viscous clutch fan as it is fitted with AC but it doesn't, i know for fact that it has factory AC as the original owner gave me a few pics of it when it was a day old, (not on computer, and i dont have a scanner) showing the AC in the engine bay. I am hoping somebody else who has a VK with Factory AC and is a 6 carbie like mine could verify this. Also would like to know if you recommend putting one regardless and if you think they improve cooling efficiency.
    Thanks
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    clutch fans do bugger all.... seriously. they just assist with acceleration. other than that a solid fan is better.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    hmmm the only advantage over my 6 blader is it has larger and more blades which would move more air.
    which would help in traffic, but on the open road the fan doesnt really do anything anyway.
    VH SS
    May 2009
    Toowoomba, Qld
    the clutch fan is a bigger diameter fan, so yeah cooling is greatly increased over the smaller fan.
    But if your A/C works fine and the engine doesn't overheat, no real advantage in changing it. Except the clutch fan doesn't use as much power when it's not needed
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    My AC works fine but my engine runs hot but not too hot even sometimes without the AC on, i reckon it need a new radiator because its the original and it wanst used much at all untill i got it and i think ive clooged it with crap coming off the block, plus the cooling fins are starting to look a bit how you going.
    It was fine when i first got it, drove home on a 40 degree day for 450 ish kms with the gauge keeping just in the normal zone abit under 1/4 but now if i try and drive like that it runs about 3/4 and youve got to remember how optimistic factory gauges are in these old beasts. Anyway my fixed fan seems to do the job for now and with a new radiator it should all be sweet
  1. New Clutch for VT
    By vt s in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2009, 08:24 PM
  2. clutch kit
    By adamandtanya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-11-2007, 09:55 AM
  3. VH viscous hub
    By jlenon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-12-2005, 09:59 AM
  4. viscous fan clutch
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 28-10-2005, 06:02 PM
  5. Viscous Coupling -> Electric Fan
    By jetspin_vn in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-01-2004, 10:52 PM
Tags for this Thread
