Results 1 to 5 of 5
Thread: VK vent/fan control problems
    VT Supercharged
    Apr 2009
    Default VK vent/fan control problems
    HI,
    got a VK 202 black with carby and AC, but having issues with fan etc.
    -the ac was not hooked up so put a belt on and can hear it kick in but not cold (gas?)
    had not been used for years.
    -the AC/fan switch I replaced as it was only blowing on 1 and new switch it goes 1-4, also the rear vacumn lines were all stuffed up and not even connected, so I thought this is the likely reason the fan will only blow through the demister but fixed it all and it still only blows via demister??? any ideas?
    jas
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Quote Originally Posted by zaczac View Post
    lol, mine has done that too. but mine was working fine, took all the hoses off one by one, snipped the ends off to make a nice tight seal so i didnt have any vac leaks, now all it does it make a sucking noise and blow out the floor vents only...
    i would love to know what i did wrong. i think my vac selector is naffed and when i put a strong vac to it the seals buggered up. it may be the case for yours too.
    tha AC stuff i dunno. dunno why anyone would want AC, but yeah, each to their own.
    85 VK SL - 79 VB 253
    Jun 2009
    NSW
    When you reconnected the vac lines to the round plastic selector, were the lines still numbered?
    Little white stickers. Can be a PITA to get them right.
    Also, in the engine bay, is the non-return valve on the vac feed line in a serviceable condition?
    Mine was borked and caused all sorts of problems.
    VT Supercharged
    Apr 2009
    fixed it!
    turns out the bloody vac line was not getting any suction? dodgey vac port or something, so hooked the 'vac in' line to a new vac port and works perfectly now!
    finally fixed, now all I need is a re-gas.
    PS don't know how anyone can get by without AC, especially in QLD!
    LOL
    j
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by codfishface View Post
    Yeh my 1 way valve is cactus so when you accelerate hard with it on norm mode the cool air goes from your face to your feet as i guess one vent opens with vacuum and the other closes.
  1. Air vent control
    By ManVRHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2010, 10:57 PM
  2. Air Vent Control broken
    By nathan.r779 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2009, 03:22 PM
  3. Climate control problems
    By VSSECO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2008, 08:09 AM
  4. Cruise control problems
    By CANYONERO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-05-2008, 11:53 AM
  5. vent control
    By micko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2004, 07:47 AM
