Results 1 to 17 of 17
Thread: Convert 253 to 308
    lil_mickey's Avatar
    lil_mickey is offline LOUD AND PROUD
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    Default Convert 253 to 308
    As the title suggest, I am swapping a 253 out to a 308 in an auto VH
    (next step is to sell the car if problems persist)
    I mainly need to know if the auto x-member, auto linkages and tail shaft are the same for the t400 as the trimatic.
    also is there somthing anyone thinks i might have missed?
    Just my 2 cents worth...
    Quote Originally Posted by wraith View Post
    Your not cool till your car looks like a dog with worms.
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    it should fit no worries, provided the 308 is an aussie pattern, not a turbo pattern...pretty sure all 253's came with aussie pattern gearboxes.
    Need some parts for my VH 253:
    Green standard steering wheel...Green lower B-pillar covers.
    Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
    PM with any info.
    lil_mickey's Avatar
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    ahh, so 308 did come out in front of trimatic?
    well that will solve all probs
    lil_mickey's Avatar
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    how long will a trimatic last behind a 308 and how much work to upgrade later?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    depends on how you treat it. mine is holding up fine my mate has a 50 dollar trimatic behind his 308 1 tonner. it gets treated like crap and is still running smooth as the day we put it in.
    lil_mickey's Avatar
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    cool, thats reassuring,
    sounds like this is a smaller job than i thought.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    if u just do a straight 253 to 308 (trimatic bolt pattern) swap its a simple change over, unbolt the old bolt in the new.
    to swap trimatic to T400, hmm this is testing the memory. u definately need a new tailshaft yoke, 99% sure u need to shorten the tailshaft and get a new x-member, i'm unsure but i doubt the stock shifter will work with a T400, just get a cheap B&M shifter off ebay or parts peddler. and if ya new 308 is trimatic bolt pattern u will need an adaptor plate kit to go a turbo pattern box.
    if u are looking to upgrade to a 308 and stronger box, i would get a turbo pattern 308 and a turbo 350 box behind it. no need for adaptor kit, the stock tailshaft fits T350, all u need is a $100 crossmember and a $300 shifter (and a bigger convertor while ur at it would be nice) and ya set
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    lil_mickey's Avatar
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    Quote Originally Posted by dirt drifter View Post
    Cheers, will prob be happening just after easter so i have a bit of time to sort it all out...
    Good to know about the tail shaft with t350.
    vb sle
    Jan 2009
    adelaide
    keep the trimatic cheap to fix cheap for parts exept stalleys dont drain power why do you think they put them behind rb30?? coz there better
    VN manual, VC 5L Auto, VT Senator 5.7, VL 308 4spd
    Aug 2008
    SouthWest WA
    I have a trimatic behine my VT fuel injected 5L in my VC, and she's copped a hammering, specifically down the quarter, and i've had stuff all problems with it. Storng as andd i love having just the 3 gears............it goes like a shower of poo!!!! lol
    Follow Your Dreams......RIP Brocky 1945 - 2006......May God Rest Your Soul
    ari666's Avatar
    1966 impala
    Mar 2009
    lil_mickey's Avatar
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    Quote Originally Posted by ari666 View Post
    Quote Originally Posted by W84N01 View Post
    ...that sounds pleasant.
    Does doesn't it?
    Thanks for the help,
    I am now looking for a 308 with aussie pattern, all i need is block, heads and insides in working order...
    Bout to post in WTB after a ring around,
    Also will my torker run good with my 4brl quaddie on a 308?
    VS Vacationer
    Mar 2010
    Geelong, Vic
    lil_mickey's Avatar
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    Quote Originally Posted by VSColl View Post
    Good luck with the hunt
    Lol, thanks Mum...
  15. #15
    ari666's Avatar
    1966 impala
    Mar 2009
    lol, i will swap ya:
    a cam (495 lift 222 duration 112 seperation) used but good, swapped it out for a crane 286
    a 6000-ish km old timing chain set (quite new, swapped for adjustable chain/gearset)
    a set of working vk black heads with LT1 springs (swapped for heads with bigger valves, ported etc)
    a stock vk manifold (swapped for edelbrock performer)
    a rusty but no holes COMPLETE 2.25" exhaust system for 308 VK including extractors (swapped for pacemaker 2.5")
    for your torker manifold!!!!
    also have boxes of various bits you can go through, with crap in it like pistons/rods, bolts, brackets air cond pumps, belts etc.
  16. #16
    lil_mickey's Avatar
    VH 253 :-)
    Jul 2006
    Geelong; Victoria
    Lol, I take that as a yes to my question...
  17. #17
    ari666's Avatar
    1966 impala
    Mar 2009
    when i was building my engine the first time with the bits that im offering i was advised to stay away from single plain maniolfds, especially with a auto trans. the reason being that you lose velocity on your inlet having such a massive plenum then meeting restrictive inlet ports. unless you are planning to open your ports up extremely and get high flow out of them (which will cost you a bunch to get done) your better of going with a performer dual plane.
    the reason i am looking for the single plain is my engine has gone past the need for dual plane and it needs to breathe. in fact i would be willing to include the edelbrock performer i am using atm into the swap. which suits a mildy cammed stock CR 308 perfectly. better than a torker. but you would need to hang around while i take it off
    all the other stuff is just laying around my workshop taking up space, but i never got around to ebaying it.
    edit* BAH! just realised your manifold will be the single bolt egr style... which wont work on black heads
  1. convert my v6 to v8
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2008, 02:30 PM
  2. To convert or to get a new one
    By jimiemick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2006, 05:50 PM
  3. vt convert to vs
    By lennys in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-02-2006, 05:34 PM
  4. WTB VS V8 gas convert
    By LethalVS in forum Swap / Wanted to Buy / Trade
    Last Post: 19-11-2005, 04:24 PM
  5. How To Convert Hp To Kw
    By Garth in forum General
    Last Post: 05-01-2004, 08:10 AM
Tags for this Thread
