ok well i have the fuel injected 202 from my vk sittin in my torana. all the wiring is hooked up and fuel line and pump hooked up. got pressure in the fuel line but no fuel gettin pumped into the injectors. tried a bunch of things and cant figure it out. any ideas guys?
Silly question, but you do have the VK ECU fitted don't you?
yea the whole wiring even the battery from the vk is in it and all hooked up. basically its the whole engine set up just with a torana shell around it. and the engine ran a dream before i swaped it. even after the crash. any ideas?
Obviously something isn't hooked up. Is the injector relay OK? Maybe it came loose?
well i pulled the injector plug off and tested that and its getting power there.
while i got somone that seems to wanna help um next thing i gotta do is replace the sump and pickup so its situated at the back. now i been told a hq 202 sump and pick up will fit just wondering what problems i might encounter there? ever done it?
No, never done it, but have you considered using a sump and pick up off a Torana 6? They came out in them as well. But then they may be the same as the HQ-HZ as well.
yea torana sump is same as hq sump just easier to find an old hq the a torana as everyone love the torana.
yea ran the fuel return line. even got fuel returning through it when i crank it over to the fuel distributer is obviously working too.
Also you will see a bleed valve in the front of the fuel rail, witht he ignition on press the centre pin, does fuel spurt out?
If it does it means you have fuel under pressure in the fuel rail and your injectors arent firing.
have you got the earth connected on the VK injector harness common problem why they dont work.
cheers
Scott
cheers scott yea got pressure through the bleed valve. and explain where the injector harness is so i can have a check.
Just to clear up, have you used an EFI fuel pump?
yea same fuel pump and fuel filter too cos i know ya need the efi filter cos the pressure in splits the fuel die and returns to the fuel tank in a crystalised form.
