Results 1 to 8 of 8
Thread: 202 injection
    vk 202
    Mar 2010
    Default 202 injection
    i have a worked 202 and am wondering if it is possible to use injection from a black 202 on a blue 202, and what changes need to be made to the motor as in msd, recurved dizzy, cam. and will it be worth the effort time and money to do so.
    VH SL/E
    Dec 2009
    Mitcham/Boronia Vic
    You''ll probably get maybe another 20kw depending on what your set up is. You don't have to make any changes except for tapping into the electrical system for the ecu. It bolts straight on to the manifold which is a bonus!!! probably take about 2/3 hours being careful. Cost ebay sometimes have them for about 50-100 bucks with everything including ecu.
    good luck XD
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    best to use the VK manifold, fuel rail etc but use another injection system, either a delco, haltec etc. I ran an E6x on my VK for a while with very good results 6 coil packs, no air flow meter to restrict air flow , one of these days I will wire it up on the 5L. The delco units are quite good as well talk to greenfoam about it.
    cheers
    Scott
    vk 202
    Mar 2010
    if it gets injected will the msd stillbe used or will need to be removed.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    that depends what ignition system your running electronic is it? if so you could keep it and runa single coil setup or go wasted spark with 6 coil packs
    scott
    vk 202
    Mar 2010
    yes dizzy is a blue motor item that has been recurved to suit the worked motor and the coil is a hipo coil (msd brand)
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    you could use an After market computer and just do fuel or ditch the coil and dizzy and go 6 coil packs and let the computer do ignition and fuel up to you and your budget
    scott
    vk 202
    Mar 2010
    thanks heaps for the info will look into it further.
  1. gas injection
    By ryan86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-01-2010, 02:54 PM
  2. lpg injection
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-11-2007, 08:13 AM
  3. red injection kit
    By STAUNCHONE in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-10-2007, 09:55 AM
  4. Gas Injection?
    By Mr_Slim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-04-2007, 12:33 PM
  5. vk v8 injection????
    By james_VK_355 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 05-02-2005, 09:28 PM
