Results 1 to 10 of 10
Thread: 202 Engine Problem
    04 VZ Exec, HX Kingswood, VB Comm
    Aug 2008
    Sydney Easter Suburbs
    Default 202 Engine Problem
    Hey all,
    I have a strange issue happening here.
    I did 1000km in the car last weekend and the poor thing hasn't been the same.
    For a few weeks before we left i noticed it was getting harder and harder to start the car, normally it started on the 3rd go where as before normally on the first or second.
    When we got back car worked fine the next day, however ever since then it's been very sick
    Car started i got it out of the garage, then it stopped, wouldn't turn back on again, it is as if it attempts to tick over (not like a flat battery sound) but can't get ignition.
    It smells very much like petrol, when you keep trying for a few times, I've noticed that I've been loosing a bit of oil which seems to leak from the carburettor, as the air filter is on below it is a flat metal lining and somewhere below that oil is spitting out all over the wheel arch and below where the engine mount is.
    The car wont start unless i leave it for an hour or so and attempt again, once it starts it doesn't stop, unless i stop the car, if i turn it off and then want to start it again say after 5-10mins i have no hope.
    If i leave it, it works fine.
    WTF could be causing this?
    I've made sure that their is a good connection everywhere and i can't really see an issue, I have a feeling it has something to do with that oil / petrol spitting out over the wheel arch.
    I can post pics / video if needed.
    Any help would be appreciated.
    Thank You
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    how many k's does it have?
    what is the condition of ur terminals?
    whats the plug/lead condition
    whats the starter motor like?
    try narrow down the problem abit aye
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    Aug 2008
    287,000km Original.
    terminals seem fine, mind you I haven't checked the fuses, could a blown fuse cause something like this?
    New spark plugs and leads before we went away.
    Start Motor seems to be working just fine, Before this was happening 8/10 times it would start first go.
    Hope this helps a bit.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    sounds like carbie rebuild time, is it worse when its hot? like if you drive to the servo and get fuel it wont start at the servo?
    smell of fuel in the engine bay sounds like the carb is sticking and flooding the engine. you may find its using more than normal amounts of fuel as well.
    cheers
    Scott
    vk.jonno's Avatar
    Nov 2009
    south east
    yer probz carbie as scott said, hes alot smarter than me :P:P
    Aug 2008
    Hummmm crap!
    Actually it's worse when cold, I noticed that when the engine is warm it's a bit easier to start.
    If the carb is sticking will some cleaning agent help a bit?
    Fuel usage wise it was very good when we went away 400k to a tank easy.
    What do you think the leak could be? If i uploaded a few photos would it help?
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Quote Originally Posted by mainpath View Post
    Hummmm crap!
    Ok are you still running the original EST? If so could be the EST playing up you know it stands for Electronically Stuffs Timing Else it could be the electric choke on the carbie playing up.
    Dont stress if the carb needs a rebuild the hardest thing is getting the float level right couple of hours to do the job. you just need a carbie kit.
    If it is running the EST, do the universal fix and put in an electronic dizzy, try disconnecting the choke and reconnecting it see if it makes a difference, if the choke is playing up i will grab out my manual and have a post the page about it.
    cheers
    Scott
    VE ssv special ed ute
    Jan 2010
    Greystanes, NSW
    Thank You
    Could be your fuel pump leaking as I had a similiar problem on my wb ute.
    Aug 2008
    Well being a HX (i'm sorry i didn't post this before).
    VKberlina: It doesn't have an electric choke but I do have a pretty big electrical fault in the car currently.
    dannyssveute: If the fuel pump were to be leaking, where would it leak the fuel? In to the carb?
    Jan 2010
    Greystanes, NSW
    Mine was spraying fuel onto the right inner guard
  1. Gts 355 big engine problem need help please
    By fat4s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2009, 07:13 PM
  2. Engine problem!!!!!!!!!! Any help?????
    By Ms 5ltr VK in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2009, 11:32 PM
  3. vn engine fan problem
    By reaper01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2009, 07:35 PM
  4. VS Engine into VR - Problem
    By Dream Commodore in forum Electrical Wiring / Questions
    Last Post: 30-01-2009, 04:04 PM
  5. engine bay problem
    By vr_owner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2006, 12:10 AM
