Results 1 to 20 of 20
Thread: question: why would my temp go down when in reverse?
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    Default question: why would my temp go down when in reverse?
    i have a running battle with overheating, but thats a story for another day. what i DID notice today is that when the car is in reverse (automatic) the temp guage drops down significantly. i.e. it was on full and dropped to just above half.
    any clues?
    85 VK SL - 79 VB 253
    Jun 2009
    NSW
    Ahh, that's an easy one!
    When in reverse, your motor is spinning the other way, so you'll be pushing air through your rad, rather than pulling.
    Have you got your fan on the right way?
    0_o
    Sorry about that........been a long day.
    VXII
    Nov 2009
    Quite a few brands of cars (unsure about commodore - maybe do the test) will do two unusual things when reverse is selected.
    1. Turn on the cooling fans as no cooling air is being directed over the radiator when driving backwards
    2. Turn the air conditioning compressor on to circulate oil around the system to keep seals wet.
    VH SS
    May 2009
    Toowoomba, Qld
    ari666's Avatar
    1966 impala
    Mar 2009
    thanks for the replies fellas:
    twin thermo fans so yeah/no the fan isnt on backwards(good lol though, thanks mate ), no AC, thermos hard wired to ignition 'on' and the temp drops to quarter immediatly then down to half in 20 or so seconds. as soon as i put it back in P or D it goes straight back up to full. im thinking its some sort of weird wiring thing, but the temp guage has nothing do do with reverse as far as i know.
    edit* i do have a transmission cooler fitted and the radiator is bypassed. does the trans fluid flow differently when in reverse? i fail when it comes to anything trans related.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    This sounds more like dodgy wiring somewhere as driving in reverse makes your cooling system have to work harder as it only gets air flow from the fans, instead of both fans and fresh air coming through. Does your fuel gauge drop when in reverse as well? if it does it could be low + power to the instument cluster or something, and the oil pump on the transmission is driven of the input shaft and will always spin the same way as the engine so the oil is always getting pumped the same way but is directed though the gear box differently.
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    hang on i just really got confused from the first post ..... in reverse your motor is spinning the other way ? .... umm don't think so
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by 1FATVT View Post
    ^^^^lol.
    electric fuel pump also, but no, the fuel level doesnt go down.
    Jun 2009
    NSW
    My job here is complete.
    Carry on chaps!
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    Try hooking up another gauge to the engine to see if your temp gauge is at fault. It could be just a bad earth to your dash that is helped when your reversing lights come on. If your engine is actually getting hot. then try taking the fan blades off the motors and turning them over because they normally work better one way than the other, depending if you want them to suck or blow.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    You always want you fan to suck as otherwise it trys to stop air flowing through when your driving along.
    Apr 2006
    Mt Gambier SA
    What i meant with the fans is some are designed to fit infront of your radiator and blow through while others are designed to fit between your engine and radiator so they suck through your radiator.
    vk.jonno's Avatar
    vk.jonno is offline :):):)
    Vk commodore, hq one tonner, hj ute,
    Nov 2009
    south east
    i still stick with the throy the fans are on wrong..
    Quote Originally Posted by BIGbrown1 View Post
    Hey dea, financed my VS 3yrz ago, desper8 4a car, meter read 214,016kms... I PAID $14,000.00, 3yrz l8r im dealin with alot of problemz... n e cheap BUT good mechanix in west melbourne? n e info appreci8d... Fanx...
    Quote Originally Posted by Menace38L View Post
    yea if i end up getting it il lay low from the cops lol jus want it for skids etc lol
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by vk.jonno View Post
    lol, you think im a complete nonce hey? this has nothing to do with the fans. craig davies fans are designed to go upstream (in front of the rad) but i installed them down stream (behind the rad) which means not only did i have to take the fan off and turn it around (as tree cutter suggested) i also had to reverse the polarity.
    anyways, the fans blow the correct amount of air in the correct direction, the fault is in the wiring of my dash/sender somehow. i was just looking for someone that may have found a solution to this problem.
    (soz for the old thread dig, im bored)
  15. #15
    VH SL/E 5.0
    Nov 2009
    I don't suppose your inhibitor switch wiring has somehow earthed out on your dash instruments?
  16. #16
    ari666's Avatar
    1966 impala
    Mar 2009
    Quote Originally Posted by DerekP View Post
    ok, now you can call me a nonce. whats an "inhibitor switch"?
  17. #17
    VH SL/E 5.0
    Nov 2009
    Quote Originally Posted by ari666 View Post
    Sometimes called a neutral start switch. I believe it also controls reverse lights (I could be wrong on that one....)
  18. #18
    ari666's Avatar
    1966 impala
    Mar 2009
    ah ok! "neutral safety switch" in my lingo. not a bad thought really. put the reverse lights on and it messes with the signal wire to temp guage. might have to check it out, good thinkin'
  19. #19
    vk.jonno's Avatar
    Nov 2009
    south east
    ..im sorry
  20. #20
    ari666's Avatar
    1966 impala
    Mar 2009
    *smooch* .
  1. water temp gauge question ????
    By sawychri06 in forum Electrical Wiring / Questions
    Last Post: 09-04-2010, 04:13 PM
  2. VH commo temp sender question (6)
    By budgieVH in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-10-2009, 07:17 PM
  3. quick temp question..
    By goat in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2007, 10:09 PM
  4. Reverse Light Question.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-09-2006, 04:53 PM
  5. Temp Question
    By inwiththenew in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-02-2006, 06:31 AM
