Results 1 to 4 of 4
Thread: Gearbox Whine
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Default Gearbox Whine
    Since fitting a 5sp (M76) to my vk it has been very whiny, at first it was unbearable but has slowly gotten better the more i have driven it. I would just like to know anyones other experience with this gearbox when it comes to noise ( other than the sweet sound of one breaking when you dump the clutch when its behind a worked 202). I have done about 3000km since fitting it and has gotten any quieter for a about 1000km, so im guessing its just a whiny box.
    I also tried some of that Nulon G70 stuff, didnt really improve the whine but made the shift much nicer.
    vkberlina's Avatar
    Mar 2004
    NSW Central Coast
    Usually the M76 makes a bang noise followed by crunching noises.
    Have you done any work on the box, bearings etc???
    What oil are you running in the box?
    cheers
    Scott
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Im using Castrol VMX80, the owners manual suggests SAE80w, i have pulled the gearbox apart and inspected it before i fitted it. All the gears looked good with no marks or scoring, bearings looked reasonably new and so did the syncro rings. Does have a bearing noise at idle when you let the clutch out in neutral which i was a bit disappointed with but its not very bad, sort off sounds like a dry bearing though. Seemed to have been pulled apart before i did. It was out of a car at my local wreckers, it had 120 000 km on it but i didnt check if it was its original box on the CP.
    Thanks in advance.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Well I just went to Sydney and on the drive home a bearing has decided to fail, luckily it was a countershaft bearing so fourth still worked ok so it made it home on its last legs. Should have replaced them in the first place but anyway.
    Just letting you all know so you dont do what i did
  1. 5speed gearbox whine
    By marcuscarter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2008, 12:31 PM
  2. VN-VP whine
    By GreendragonDMX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2008, 12:58 AM
  3. Engine Whine
    By KLatham in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2008, 08:23 AM
  4. Diff Whine
    By Trevor 062 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-02-2007, 11:58 AM
  5. Whine in back end
    By inwiththenew in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-07-2006, 09:21 PM
Tags for this Thread
