Hi. I have a vc commy with a 253v8 and m21 box. The clutch cable has slipped off; and the pedal spring is broken; of taken the clutch pedal out and relized its for a six cylinder, I was wondering if this will work ok or should it have a v8 pedal box.
Cheers Rob
I wouldn't worry to much bout using a 6cyl pedal box with a v8. Only difference is the pivot point is different and gives ya more leverage on the pedal. As long as the clutch disengages it should be fine.
VK Wagz 308 - [Buildup Thread]
VK Wagz 253 Twin Turbo - [Buildup Thread]
VK Wagz EFI 5.0L 5spd - [Buildup Thread]
TECH: VK EFI Conversion - Fix your dead EFI 5L ignition module - Trimatic shift kit
i have photos of both 6 & 8 peddle boxes if your wondering the difference. ill find them and post them up for future reference if nothing else.
