Results 1 to 5 of 5
Thread: Spark Plugs For VH 308
    VH SL/E 5.0
    Nov 2009
    Default Spark Plugs For VH 308
    What spark plugs would you recommend for a stock 308 VH (have headers fitted tho)?. Also what is the
    correct gap setting for the plugs? I run PULP if it makes a difference.
    ari666's Avatar
    ari666 is offline captain halfajob
    1966 impala
    Mar 2009
    VH SL/E 5.0
    Nov 2009
    Quote Originally Posted by ari666 View Post
    ngk copper 5 heat range and 10mm gap.
    May I just confirm that is a 10mm gap, as in 1cm? (seems big but I'm no expert!!)
    Also I have been looking at a few catalogues and I am a bit unsure of the NGK type, would you have a part number or product description handy? So far I have only found standard NGK's for around $5 each which sounds too cheap or the irridium ones...
    VX series 2 SS 6 speed,VK Royale 308,VN V6 Ute
    Mar 2009
    Coromandel, NZ
    VC
    Oct 2008
    Default Spark plugs
    The correct plug is NGK BPR5FS-15 and the gap should be 1.5mm.
  1. Replies: 25
    Last Post: 05-02-2011, 07:52 PM
  2. Spark plugs
    By Northern_Union in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-02-2010, 02:55 PM
  3. Spark Plugs
    By calais24/7 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-02-2010, 06:35 PM
  4. Spark Plugs
    By Jack87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2007, 08:36 PM
  5. Spark Plug Leads Getting 'baked' on to Spark Plugs?
    By holden#1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-09-2005, 04:16 PM
